What's your volt meter reading when cruising around town? |
raynekat |
Jan 9 2020, 11:58 PM
Advanced Member Group: Members Posts: 2,159 Joined: 30-December 14 From: Coeur d'Alene, Idaho Member No.: 18,263 Region Association: Pacific Northwest |
Just curious what the typical volt meter reading is:
1) when you're sitting at the stoplight 2) cruising down the boulevard at 3-4000 rpm Trying to see if I'm seeing typical or low readings Thanks I just recently noted a low charging issue that I believe came down to an alternator/voltage regulator mismatch. I was using a Bosch VR with my Motorola alternator. Now I've switched to a Marchal VR and the charging voltages look better. About 13.75 volts while cruising. |
SO.O.C914er |
Jan 10 2020, 02:17 PM
Senior Member Group: Members Posts: 1,250 Joined: 18-July 16 From: Mission Viejo Ca Member No.: 20,199 Region Association: Southern California |
I’m seeing just under 14v day time driving but when I run my lights at night it drops to just above 12v is this normal....mind you this is coming from a guy who is abby normal haha (IMG:style_emoticons/default/av-943.gif)
Lo-Fi Version | Time is now: 21st May 2024 - 06:37 PM |
