What's your volt meter reading when cruising around town? |
raynekat |
Jan 9 2020, 11:58 PM
Advanced Member Group: Members Posts: 2,159 Joined: 30-December 14 From: Coeur d'Alene, Idaho Member No.: 18,263 Region Association: Pacific Northwest |
Just curious what the typical volt meter reading is:
1) when you're sitting at the stoplight 2) cruising down the boulevard at 3-4000 rpm Trying to see if I'm seeing typical or low readings Thanks I just recently noted a low charging issue that I believe came down to an alternator/voltage regulator mismatch. I was using a Bosch VR with my Motorola alternator. Now I've switched to a Marchal VR and the charging voltages look better. About 13.75 volts while cruising. |
Spoke |
Jan 11 2020, 07:17 PM
Jerry Group: Members Posts: 6,983 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
As far as LED current is concerned, my brake boards burn about 5W when on. Turnsignals about the same. So worst case is sitting on the brakes with turnsignals on. That would be
5W x 2 + 5W x 2 = 20W which is a bit lower than 2 amps. Not sure about LED headlights. I would assume 15-30W each. 1.5-2.5A each. |
Superhawk996 |
Jan 11 2020, 08:10 PM
914 Guru Group: Members Posts: 5,839 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
As far as LED current is concerned, my brake boards burn about 5W when on. Turnsignals about the same. So worst case is sitting on the brakes with turnsignals on. That would be 5W x 2 + 5W x 2 = 20W which is a bit lower than 2 amps. Not sure about LED headlights. I would assume 15-30W each. 1.5-2.5A each. So let's call that 7 amps for LED exterior lighting. But we still have some higher legacy loads: Anyone ever meausured the following items? Wiper Motor - TBD Ignition coil - TBD Radio and/or auxillary amplifiers - TBD. I know my modern radio is fused 10A (4 ch. x 25 watt RMS). Probably draws 4A steady state. Fog Lamps - depends of LED or conventional. Other goodies - radar detector, phone charging, etc. |
Lo-Fi Version | Time is now: 21st May 2024 - 10:21 AM |
