What's your volt meter reading when cruising around town? |
raynekat |
Jan 9 2020, 11:58 PM
Advanced Member Group: Members Posts: 2,159 Joined: 30-December 14 From: Coeur d'Alene, Idaho Member No.: 18,263 Region Association: Pacific Northwest |
Just curious what the typical volt meter reading is:
1) when you're sitting at the stoplight 2) cruising down the boulevard at 3-4000 rpm Trying to see if I'm seeing typical or low readings Thanks I just recently noted a low charging issue that I believe came down to an alternator/voltage regulator mismatch. I was using a Bosch VR with my Motorola alternator. Now I've switched to a Marchal VR and the charging voltages look better. About 13.75 volts while cruising. |
GeorgeRud |
Jan 18 2020, 10:33 AM
Makes me long for the days of ammeter gauges on the dash. I did install a voltmeter in the ashtray area to be able to keep track of system voltage at least. However, the glowing light is a good backup and much better than nothing.
Lo-Fi Version | Time is now: 21st May 2024 - 12:54 PM |
