What's your volt meter reading when cruising around town? |
raynekat |
Jan 9 2020, 11:58 PM
Advanced Member Group: Members Posts: 2,159 Joined: 30-December 14 From: Coeur d'Alene, Idaho Member No.: 18,263 Region Association: Pacific Northwest |
Just curious what the typical volt meter reading is:
1) when you're sitting at the stoplight 2) cruising down the boulevard at 3-4000 rpm Trying to see if I'm seeing typical or low readings Thanks I just recently noted a low charging issue that I believe came down to an alternator/voltage regulator mismatch. I was using a Bosch VR with my Motorola alternator. Now I've switched to a Marchal VR and the charging voltages look better. About 13.75 volts while cruising. |
GeorgeRud |
Jan 18 2020, 10:35 AM
Advanced Member Group: Members Posts: 3,725 Joined: 27-July 05 From: Chicagoland Member No.: 4,482 Region Association: Upper MidWest |
Spoke |
Jan 18 2020, 01:34 PM
Jerry Group: Members Posts: 6,983 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
...I don’t know how accurate the VDO voltmeter is in comparison to the plug in ones... I measured the VDO voltmeter in my car and found the voltmeter to be within 0.1V in the 8 to 16V range. The real error as we all know is connecting the voltmeter somewhere in the 914 wire loom where voltage drops are common. |
Lo-Fi Version | Time is now: 21st May 2024 - 05:16 AM |
