What's your volt meter reading when cruising around town? |
raynekat |
Jan 9 2020, 11:58 PM
Advanced Member Group: Members Posts: 2,159 Joined: 30-December 14 From: Coeur d'Alene, Idaho Member No.: 18,263 Region Association: Pacific Northwest |
Just curious what the typical volt meter reading is:
1) when you're sitting at the stoplight 2) cruising down the boulevard at 3-4000 rpm Trying to see if I'm seeing typical or low readings Thanks I just recently noted a low charging issue that I believe came down to an alternator/voltage regulator mismatch. I was using a Bosch VR with my Motorola alternator. Now I've switched to a Marchal VR and the charging voltages look better. About 13.75 volts while cruising. |
FlacaProductions |
Feb 15 2020, 08:35 PM
Senior Member Group: Members Posts: 1,591 Joined: 24-November 17 From: LA Member No.: 21,628 Region Association: Southern California |
@raynekat - that's a really good find and while I think the graphics are a bit "much" I'll say that the white doesn't look bad at all in your setup. Do you think it would work in a /4 with a rain tray? I'm guessing with it being the right code and size to fit the battery tray, it would....
Also - maybe one of the original 914 HO Campaign battery covers would fit and cover up the graphics on the top? |
Lo-Fi Version | Time is now: 21st May 2024 - 04:41 AM |
