What's your volt meter reading when cruising around town? |
raynekat |
Jan 9 2020, 11:58 PM
Advanced Member Group: Members Posts: 2,159 Joined: 30-December 14 From: Coeur d'Alene, Idaho Member No.: 18,263 Region Association: Pacific Northwest |
Just curious what the typical volt meter reading is:
1) when you're sitting at the stoplight 2) cruising down the boulevard at 3-4000 rpm Trying to see if I'm seeing typical or low readings Thanks I just recently noted a low charging issue that I believe came down to an alternator/voltage regulator mismatch. I was using a Bosch VR with my Motorola alternator. Now I've switched to a Marchal VR and the charging voltages look better. About 13.75 volts while cruising. |
Superhawk996 |
Mar 13 2020, 03:11 PM
914 Guru Group: Members Posts: 5,842 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
Glad to see its running properly for you now. Battery cover looks good. Well done!
raynekat |
Mar 13 2020, 04:38 PM
Glad to see its running properly for you now. Battery cover looks good. Well done! Yes Superhawk. You were definitely the motivation/inspiration to upgrade my battery/voltage regulator on my car. What I had was fine for a dedicated track car, but not so much for a street car. I learned a lot on this voyage. Many, many things I just didn't know about it. Sometimes knowing enough to be "dangerous" is just that....dangerous! Ha (IMG:style_emoticons/default/biggrin.gif) |
Lo-Fi Version | Time is now: 21st May 2024 - 06:19 PM |
