battery connection screw up |
dt4 |
Jan 12 2020, 09:57 AM
Senior Member Group: Members Posts: 502 Joined: 26-May 19 From: England Member No.: 23,161 Region Association: England |
I have had the battery off the car whilst stripping paint and priming etc.... but thought it would be good to turn the engine over and run it for a while to keep things in good health etc.....
I had the battery on the bench to charge it and then put it back in the car but very stupidly put the negative lead to positive terminal and positive lead to negative terminal. I didnt turn the key as I was checking other things when I realised what I had done. I noticed that there was a smell of smoke coming from the alternator area and the tin on top of the engine in that area was warm so suspect there is a connector to the alternator under there? I put the terminals on the right way around and tried to start the engine but it appeared the battery had drained? I recharged the battery overnight but wouldnt start, again the battery seemed low on charge Apart from seemingly screwing the battery, is there other damage likely to have occured cheers David |
dt4 |
Feb 12 2020, 01:32 AM
I guess I can make this easier to get the jumper leads to the starter by putting the battery under the car? so not having to thread them down and around and also not as likely for the positive to contact something it shouldn't?
I am clear on which is the positive for the starter could some one show which is the negative or is it obvious once I get back under and take another look? Many thanks for the pointers chaps (IMG:style_emoticons/default/thumb3d.gif) |
Lo-Fi Version | Time is now: 4th May 2024 - 03:24 AM |
