battery connection screw up |
dt4 |
Jan 12 2020, 09:57 AM
Senior Member Group: Members Posts: 502 Joined: 26-May 19 From: England Member No.: 23,161 Region Association: England |
I have had the battery off the car whilst stripping paint and priming etc.... but thought it would be good to turn the engine over and run it for a while to keep things in good health etc.....
I had the battery on the bench to charge it and then put it back in the car but very stupidly put the negative lead to positive terminal and positive lead to negative terminal. I didnt turn the key as I was checking other things when I realised what I had done. I noticed that there was a smell of smoke coming from the alternator area and the tin on top of the engine in that area was warm so suspect there is a connector to the alternator under there? I put the terminals on the right way around and tried to start the engine but it appeared the battery had drained? I recharged the battery overnight but wouldnt start, again the battery seemed low on charge Apart from seemingly screwing the battery, is there other damage likely to have occured cheers David |
dt4 |
Feb 11 2020, 01:57 PM
I got the Mrs to turn the key whilst I checked battery volts, one battery dropped from 12.5 to 9.5, the other dropped from 12.5 to 10.6
does that suggest healthy battery and a dodgy starter motor? can a starter motor be tested on the bench with a battery? |
ctc911ctc |
Feb 11 2020, 02:08 PM
Senior Member Group: Members Posts: 890 Joined: 9-June 18 From: boston Member No.: 22,206 Region Association: North East States |
If the wiring is solid, all connectors tight and clean - I would move to the starter mother/solenoid as the culprit Also, is the starter fully engaged? Does the motor turn? Makes that Errr,Errr, Errr noise? Or, do you hear clicking? Errrr,,, Click,Click,Errr,Errr,Click,Click???
DOUBLE CHECK THE WIRING -please,,,,,,,, (IMG:style_emoticons/default/biggrin.gif) I got the Mrs to turn the key whilst I checked battery volts, one battery dropped from 12.5 to 9.5, the other dropped from 12.5 to 10.6 does that suggest healthy battery and a dodgy starter motor? can a starter motor be tested on the bench with a battery? |
Lo-Fi Version | Time is now: 20th April 2024 - 04:41 AM |
