Frame brace instructions needed |
Stuckon914 |
Jan 14 2020, 12:48 AM
Member Group: Members Posts: 132 Joined: 25-December 18 From: East coast Member No.: 22,747 Region Association: MidAtlantic Region |
Starting to work on my 914, longs likely need to be replaced. I would like to stabilize the frame using the adjustable brace I see some use that is attached To the door opening and has adjustable turn-buckles.
Where can I find some instructions on building them? Tried search and google with no luck. |
Superhawk996 |
Jan 14 2020, 10:46 AM
914 Guru Group: Members Posts: 5,670 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
Heim joints and threaded bungs to make adjustable braces are cheap and available on Amazon.
Stuckon914 |
Jan 14 2020, 04:48 PM
Charles Freeborn |
Jan 14 2020, 05:19 PM
Member Group: Members Posts: 244 Joined: 21-May 14 From: United States Member No.: 17,377 Region Association: Pacific Northwest |
Heim joints and threaded bungs to make adjustable braces are cheap and available on Amazon. Learned two new terms. Thought you might be making Up terms for a minute There's a whole wonderful vocabulary of fabrication terms.. Rivnuts, Nutserts, Flangebolts, and my favorite ... swarf... it's the curlycues and chips that you sweep up and throw away (or recycle) that comes from lathe, and milling operations. |
Stuckon914 |
Jan 14 2020, 07:01 PM
Heim joints and threaded bungs to make adjustable braces are cheap and available on Amazon. Learned two new terms. Thought you might be making Up terms for a minute There's a whole wonderful vocabulary of fabrication terms.. Rivnuts, Nutserts, Flangebolts, and my favorite ... swarf... it's the curlycues and chips that you sweep up and throw away (or recycle) that comes from lathe, and milling operations. Rivnuts and nutserts sound like terms used to pull someone’s leg. |
Lo-Fi Version | Time is now: 28th March 2024 - 03:55 AM |
