Master cylinder reservoir cover |
Bleyseng |
Jan 15 2020, 01:20 PM
Aircooled Baby! Group: Members Posts: 13,034 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest |
Where can you get one ?
Attached image(s) |
burton73 |
Jan 15 2020, 04:14 PM
burton73 Group: Members Posts: 3,525 Joined: 2-January 07 From: Los Angeles Member No.: 7,414 Region Association: Southern California |
This is really easy if Garold used his part for tooling. Clean it and pour into it with aluminum filled Polly Urethane and then use that for the tooling. Parts can be made by vacuum forming. Pulling over the tool with .060 or .090 polyethylene on a small Vacauform. I have a retired unit here at my shop.
Set up a tool for cutting and then use a router to cut the parts. Bob Burton -- Burton Plastics-- Burton73 (IMG:style_emoticons/default/bye1.gif) |
Mikey914 |
Jan 16 2020, 01:28 AM
The rubber man Group: Members Posts: 12,670 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
This is really easy if Garold used his part for tooling. Clean it and pour into it with aluminum filled Polly Urethane and then use that for the tooling. Parts can be made by vacuum forming. Pulling over the tool with .060 or .090 polyethylene on a small Vacauform. I have a retired unit here at my shop. Set up a tool for cutting and then use a router to cut the parts. Bob Burton -- Burton Plastics-- Burton73 (IMG:style_emoticons/default/bye1.gif) Due to the undercut, vacuforming wouldn't work as well as injection molding, but I have a unit and may try 1st to see. |
Lo-Fi Version | Time is now: 19th May 2024 - 09:19 AM |
