Has anyone ever made a 914/8 clone?, Or am I off my rocker? |
Mikey914 |
Jan 16 2020, 10:09 AM
The rubber man Group: Members Posts: 12,639 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
I have seen a few tribute GT cars that are great, but you all know me. I really love doing the obscure.
I have access to some aircraft cases and was thinking about taking 2 IO540s and adding another bank of pistons to one. Yes machining the cases, welding it all up and same with the crank. Wouldn't be cheap, or easy. But if I could make the motor, I could do the rest. Anyone know what the displacement was ? Or any other specs Attached image(s) |
Beebo Kanelle |
Jan 16 2020, 10:16 AM
Member Group: Members Posts: 248 Joined: 22-November 12 From: Houston, Texas Member No.: 15,177 Region Association: Southwest Region |
3 liters... 300bhp
Although I believe there was also a 2.1 liter turbocharged version that had approx 4-500 bhp But I could be wrong. |
AZBanks |
Jan 16 2020, 10:18 AM
Senior Member Group: Members Posts: 1,057 Joined: 7-December 05 From: New River, AZ Member No.: 5,245 Region Association: Southwest Region |
You're insane!
I like it. |
mepstein |
Jan 16 2020, 10:45 AM
914-6 GT in waiting Group: Members Posts: 19,244 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
It was the 908 race engine and 908 trans. Since the 908 was already mid engined, it fit really well - once Porsche moved the trunk firewall. Using an aircraft engine will be more work than Porsche had to do since you have to fit everything around the engine, adapt a trans, clutch, headers, etc. and then you don’t really see anything in a 914 engine bay.
I do want to do a silver 914-8 tribute but just exterior and interior. I’ll be happy with a six in the engine bay. |
Mark Henry |
Jan 16 2020, 11:01 AM
No, but it has been done with VW engines. In fact IIRC young Emerson Fittipaldi did this when he was still an up and comer racer in Brazil.
Why I say no is because aircraft and automotive engines are very different. Aircraft engines spin at slow speeds, 3000rpm redline, where they make the HP is with very long strokes and big pistons, 0-540 is 130.2 piston X 111.1mm stroke. Automotive engines use much smaller bore and stroke, and a higher 6000 and up RPM, in the case of the 908, 85mm bore X 66mm stroke with a peak power of 370hp at 8400rpm. It would be easier to weld two VW T1 engines together and then use SCAT split port heads. But then the engine is too freaking long...and for the coin you spend on custom machining you could likely have a real nice /6 conversion. |
GregAmy |
Jan 16 2020, 11:07 AM
Advanced Member Group: Members Posts: 2,268 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States |
The IO-540 was designed with a redline of 2700 RPM. Not only are you talking about welding in a case and crankshaft, but also completely redesigning the engine from the inside out.
So, yeah, you're off your rocker. (IMG:style_emoticons/default/wink.gif) You're *far* better off trying to find an actual 908 engine... |
Mark Henry |
Jan 16 2020, 11:13 AM
Emerson Fittipaldi, flat 8 VW engine.
https://jalopnik.com/emerson-fittipaldis-do...-beetle-5799726 Edit: correction, I was a bit off, this was two engines coupled together. |
Mark Henry |
Jan 16 2020, 11:20 AM
sixnotfour |
Jan 16 2020, 11:21 AM
914 Wizard Group: Members Posts: 10,412 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
my new favorite pic.... porsche 8cyl
911 based Attached image(s) |
tomeric914 |
Jan 16 2020, 11:22 AM
One Lap of America in a 914! Group: Members Posts: 1,259 Joined: 25-May 08 From: Syracuse, NY Member No.: 9,101 Region Association: North East States |
You're *far* better off trying to find an actual 908 engine... (IMG:style_emoticons/default/agree.gif) It's interesting though, I never noticed that they had moved the firewall back on the 914-8 until just now. The picture always seemed a bit off but I couldn't put my finger on what was different. (IMG:style_emoticons/default/wacko.gif) |
Mark Henry |
Jan 16 2020, 11:32 AM
The cheapest way to do this would be to use a Tatra V8 air cooled engine.
https://www.youtube.com/watch?v=ao5OF7EXDcw https://www.youtube.com/watch?v=dFXDgrLtNWo |
tomeric914 |
Jan 16 2020, 11:35 AM
The cheapest way to do this would be to use a Tatra V8 air cooled engine. Do we have to crank start it every time? Seems about right (IMG:style_emoticons/default/lol-2.gif) |
ClayPerrine |
Jan 16 2020, 11:36 AM
Life's been good to me so far..... Group: Admin Posts: 15,416 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
Emerson Fittipaldi, flat 8 VW engine. https://jalopnik.com/emerson-fittipaldis-do...-beetle-5799726 Edit: correction, I was a bit off, this was two engines coupled together. Two 2.2 hot rodded VW Beetle engines in a 1100 lb Beetle chassis. 400+ HP and it had a swing axle suspension and DRUM BRAKES!!!!! And you think I am crazy for building my 4.0L 914. This makes me look like a piker....... |
ConeDodger |
Jan 16 2020, 11:46 AM
Apex killer! Group: Members Posts: 23,569 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
Just do a really well done V8 conversion. No one will question your sanity except those of us who know you personally. (IMG:style_emoticons/default/blink.gif) as far as the other is concerned, you practically have an in-house machine shop now so... (IMG:style_emoticons/default/drooley.gif)
Mark Henry |
Jan 16 2020, 11:49 AM
The cheapest way to do this would be to use a Tatra V8 air cooled engine. Do we have to crank start it every time? Seems about right (IMG:style_emoticons/default/lol-2.gif) No they are electric start, but it's a 1930's Czech design, back when the batteries weren't so reliable. There's another YT vid with a guy starting the engine with a tie down strap. |
GregAmy |
Mark Henry |
Jan 16 2020, 11:53 AM
Just do a really well done V8 conversion. No one will question your sanity except those of us who know you personally. (IMG:style_emoticons/default/blink.gif) as far as the other is concerned, you practically have an in-house machine shop now so... (IMG:style_emoticons/default/drooley.gif) I agree, a LS alunimum engine would be my choice, I've been thinking about doing this to a 996. |
jtprettyman |
Jan 16 2020, 11:59 AM
Rust Bucket Owner Group: Members Posts: 109 Joined: 5-May 15 From: Murfreesboro Tennessee Member No.: 18,707 Region Association: South East States |
Why sell yourself short at 'just' an 8? If you're gonna be a bear, be a grizzly.......
Attached image(s) |
Mark Henry |
Jan 16 2020, 12:06 PM
Why sell yourself short at 'just' an 8? If you're gonna be a bear, be a grizzly....... You might have add a couple feet to the 914 for this... (IMG:style_emoticons/default/laugh.gif) |
sixnotfour |
Jan 16 2020, 12:10 PM
QUOTE I agree, a LS alunimum engine would be my choice, I've been thinking about doing this to a 996. so much a better engine... I think the quad headlights would be far out.. the body sure looks tortured in this pic (IMG:style_emoticons/default/driving.gif) Attached image(s) |
Lo-Fi Version | Time is now: 29th April 2024 - 01:19 AM |
