Shift rod - Update- new brass bushings, and another option-a 911 coupler from Rauch & Spiegel, Is this a normal looking rod? And how the heck do I get the pin out? |
DRPHIL914 |
Jan 16 2020, 04:57 PM
Dr. Phil Group: Members Posts: 5,766 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
A few issues here , after the bushing disintegrated I ordered new stuff, a new firewall bushing from RIX914PARTS and other goodies from 914rubber.com, and a new brass bushing for the coupling, however I can’t get the pin out, and I’m going to mess up the pin end and it’s not going to slide thru if I do that- so I’m going to have to find a press I guess somewhere?
1. Should it be that tight ? 2. Is this a normal weld end? Attached thumbnail(s) |
DRPHIL914 |
Jan 30 2020, 12:41 PM
i wish I had taken better pictures of the pin to show how the 3 spines are. its like they made a little cut and it causes it to bow out just enough that this is why it is hard to get them out. With mine it was original and never out before, so I had a good bit of rust holding it in as well. Once I had it out and cleaned it up with some 1000grit sand paper, it was much easier to press it into place, but still not easy and this is good. I also had to file smooth the ends since I had marred the one end from trying to strike it with a hammer. anyway if you do this and it is really easy to press it into place, you might want to do what Rauch and Spiegel does and drill and counter sink and tap for a threaded set screw to make sure the pin does not come out.
Lo-Fi Version | Time is now: 17th May 2024 - 02:58 AM |
