Shift rod - Update- new brass bushings, and another option-a 911 coupler from Rauch & Spiegel, Is this a normal looking rod? And how the heck do I get the pin out? |
DRPHIL914 |
Jan 16 2020, 04:57 PM
Dr. Phil Group: Members Posts: 5,766 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
A few issues here , after the bushing disintegrated I ordered new stuff, a new firewall bushing from RIX914PARTS and other goodies from 914rubber.com, and a new brass bushing for the coupling, however I can’t get the pin out, and I’m going to mess up the pin end and it’s not going to slide thru if I do that- so I’m going to have to find a press I guess somewhere?
1. Should it be that tight ? 2. Is this a normal weld end? Attached thumbnail(s) |
914Sixer |
Jan 30 2020, 02:11 PM
914 Guru Group: Members Posts: 8,885 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Here is mine using the later stouter 911 coupler. 911 has extra gussets. Used anti-seize compound on pin because of difference of metal.
Attached image(s) |
DRPHIL914 |
Jan 30 2020, 05:27 PM
Here is mine using the later stouter 911 coupler. 911 has extra gussets. Used anti-seize compound on pin because of difference of metal. I saw those on like and wondered how they fit, looks good! I probably should have used one of those rather than the weaker stock cast one. Good to know we do have a few options if the original is damaged or lost. The bronze bushings make it super tight don’t they! |
Lo-Fi Version | Time is now: 20th May 2024 - 12:18 AM |
