> Shift rod - Update- new brass bushings, and another option-a 911 coupler from Rauch & Spiegel, Is this a normal looking rod? And how the heck do I get the pin out?
DRPHIL914
post Jan 16 2020, 04:57 PM
Post #21
Dr. Phil
A few issues here , after the bushing disintegrated I ordered new stuff, a new firewall bushing from RIX914PARTS and other goodies from 914rubber.com, and a new brass bushing for the coupling, however I can’t get the pin out, and I’m going to mess up the pin end and it’s not going to slide thru if I do that- so I’m going to have to find a press I guess somewhere?
1. Should it be that tight ?
2. Is this a normal weld end?
DRPHIL914   Shift rod - Update- new brass bushings, and another option-a 911 coupler from Rauch & Spiegel   Jan 16 2020, 04:57 PM
dr914@autoatlanta.com   lube the pin, support the coupler in a vice with w...   Jan 16 2020, 05:25 PM
BeatNavy   That was one of the more frustrating tasks I'v...   Jan 16 2020, 06:05 PM
mepstein   You will never regret getting a press. It’s one ...   Jan 16 2020, 06:14 PM
BeatNavy   You will never regret getting a press. It’s one...   Jan 16 2020, 06:34 PM
jmitro   You will never regret getting a press. It’s one...   Jan 16 2020, 10:27 PM
Chris914n6   2. Normal The coupler is not that strong. It...   Jan 16 2020, 06:36 PM
poorsche914   2. Normal The coupler is not that strong. It...   Jan 16 2020, 09:12 PM
DRPHIL914   2. Normal The coupler is not that strong. It...   Jan 16 2020, 09:19 PM
IronHillRestorations   I've done a bunch of those. I use two sockets...   Jan 16 2020, 11:04 PM
anderssj   Dr. Phil, A couple of links I found helpful: htt...   Jan 17 2020, 08:53 AM
rhodyguy   From the pictures the pin ends look pretty distort...   Jan 18 2020, 11:32 AM
IronHillRestorations   From the pictures the pin ends look pretty distor...   Jan 18 2020, 12:14 PM
DRPHIL914   From the pictures the pin ends look pretty disto...   Jan 18 2020, 03:21 PM
DRPHIL914   https://sierramadrecollection.com/Shift-Cou...-88-...   Jan 18 2020, 03:26 PM
Mikey914   Why replace a perfectly good part ? You still have...   Jan 18 2020, 04:19 PM
Mark Henry   Six inch vice, the two socket method....and that w...   Jan 18 2020, 07:29 PM
rhodyguy   1/2 step forward and 4 steps backwards with those ...   Jan 18 2020, 08:59 PM
mlindner   DrPhil, if all fails, I do have a nice one for sal...   Jan 19 2020, 06:26 AM
DRPHIL914   DrPhil, if all fails, I do have a nice one for sa...   Jan 19 2020, 06:01 PM
Tdskip   Personally I’d replace it since if the repairs a...   Jan 19 2020, 07:57 AM
TheCabinetmaker   911 has an oval hole in the bushings that won...   Jan 19 2020, 08:43 AM
DRPHIL914   Ok tried getting the pin to move with clamp press ...   Jan 20 2020, 08:01 PM
mepstein   Ok tried getting the pin to move with clamp press...   Jan 20 2020, 08:06 PM
DRPHIL914   Posting an update! I had given up after taking...   Jan 30 2020, 11:52 AM
SirAndy   :first:   Jan 30 2020, 12:15 PM
DRPHIL914   i wish I had taken better pictures of the pin to s...   Jan 30 2020, 12:41 PM
914Sixer   Here is mine using the later stouter 911 coupler. ...   Jan 30 2020, 02:11 PM
DRPHIL914   Here is mine using the later stouter 911 coupler....   Jan 30 2020, 05:27 PM
DRPHIL914   Update: Just got a couple pictures of that shift ...   Feb 21 2020, 08:51 AM
Olympic 914   That s the first time I have seen the bronze coupl...   Feb 21 2020, 06:58 PM
DRPHIL914   That s the first time I have seen the bronze coup...   Feb 21 2020, 07:11 PM
maf914   That s the first time I have seen the bronze coup...   Feb 23 2020, 07:41 AM
- Lo-Fi Version Time is now: 2nd April 2026 - 07:03 PM
