Weltmeister 19mm front sway bar bushings, ...anyone got a source? |
naro914 |
Jan 17 2020, 09:48 AM
Losing my mind... Group: Members Posts: 2,476 Joined: 26-May 06 From: Charlotte, NC Member No.: 6,073 Region Association: South East States |
A friend of mine is looking for the bushings for where the bar goes through the body for a 19mm Weltmeister sway bar. Any idea where to get these?
mskala |
Oct 22 2023, 03:48 PM
R Group: Members Posts: 1,925 Joined: 2-January 03 From: Massachusetts Member No.: 79 Region Association: None |
I just did some bushing work on my old 19mm Weltmeister front bar.
The bushings are not quite the same as the ones shown for 22mm. I made new out of delrin, which is probably not the best material for this but the huge bearing surface should make it okay for most uses. The dimensions you need are 1.505" long, 1.128" OD, 0.752" ID. No lip on either end, the piece bolted to the fender well has a stop on the inside. As others have said, there is some room for the bar to move sideways, so be prepared after pushing the arm as far as it will go, to have a small spacer to fit in-between the bushing and arm. |
Lo-Fi Version | Time is now: 10th May 2024 - 03:50 AM |
