Quick sanity check / look OK? |
dr914@autoatlanta.com |
Jan 18 2020, 04:48 PM
914 Guru Group: Members Posts: 7,820 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
heat exchangers are backwards
Good morning. Going to drop the engine on the turbo car today, will make sure to take pictures of the engine that’s in there because I know this has been a point of significant Does this look OK - will this work as pictured on a ‘75 2.0L set up? |
Tdskip |
Jan 18 2020, 06:52 PM
Advanced Member Group: Members Posts: 3,684 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None |
Thanks Jett. As it turns out a local 914 world guy reached out to me yesterday afternoon and I literally just picked up a more stock set up that I will be installing instead of the one I pictured. Thank you for the post however, hopefully someone else can make good use of it. So did you get early stock HE's? or SSI's? T1 and 4 any time I've tried a 4-1-2 system it's loud as fuch, on my bus it was so bad I capped one of the tips off. Hi Mark - going with a stock ‘75 set up for now. Just need to get it back on the road so I can push some other projects forward. I’m thinking this car will likely be the one that gets the 3.2l later this year so trying to keep the spend down for now. Thanks for asking! @dr914 @autoatlanta.com - thanks, figured that out when I was test fitting everything on the bench. Got them on, I think anyway, the right way now. Thanks for the eyes on them. |
Lo-Fi Version | Time is now: 27th April 2024 - 12:04 PM |
