Mystery engine is out |
Tdskip |
Jan 19 2020, 06:44 PM
Advanced Member Group: Members Posts: 3,684 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None |
@mb911 - that is a poor excuse, LOL.
Looks like I messed up the alignment of that shifter cone screw, might be the gear selection issue. |
KevinW |
Jan 19 2020, 07:12 PM
Newbie Group: Members Posts: 42 Joined: 25-May 15 From: Winona, Minnesota Member No.: 18,761 Region Association: Upper MidWest |
I think you have the wrong plastic bushing holder.
Attached thumbnail(s) |
rgalla9146 |
Jan 19 2020, 09:27 PM
Tdskip |
Jan 19 2020, 10:16 PM
Good eyes guys, let me swap that out and see where it gets me.
Thanks! |
914Toy |
Jan 20 2020, 10:13 AM
Senior Member Group: Members Posts: 716 Joined: 12-November 17 From: Laguna beach Member No.: 21,596 Region Association: Southern California |
Tom, perhaps you already know, but if I see it correctly, you have too much play between the shift rod and the white plastic bushing. If so, there is much shifting improvement available from improving this fitment.
Tdskip |
Jan 20 2020, 10:14 AM
Chi-town |
Jan 20 2020, 10:27 AM
Senior Member Group: Members Posts: 850 Joined: 31-August 18 From: Disneyland Member No.: 22,446 Region Association: Southern California |
Yep, that's a tail shift selector cup.
If you need a side shift one let me know I have many. |
Tdskip |
Jan 21 2020, 11:34 AM
ClayPerrine |
Jan 21 2020, 01:44 PM
Life's been good to me so far..... Group: Admin Posts: 15,410 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
So the good news is I was able to drive the car around the block and it seems healthy, but it’s not as torquey as that engine that you and Forrest help me with Keith @914Toy I also found a goodie I did not know I had! The bad news is that my test drive was only in 2nd and 4th gears since I need to adjust the shifter. Before I dive into that could I get eyes on this please? Don’t think this should be much of any of the white plastic showing, should there? There are two different connectors for the cup bushings. The one in your picture is for an early 911 or 914, and is used under the shifter. The other one is longer, and is used with the side shift console. You have the wrong one in there. |
Tdskip |
Jan 21 2020, 02:32 PM
Thanks @ClayPerrine
That was how it came to me, fixed it now. Too a coupe tries to align the shifter but I am back on the road. So far so good but I have a bad flat spot on the dual carbs when I give it gas from lower RPM, but I can deal with that later. Thanks for all of the help and PMs gentlemen! |
ndfrigi |
Jan 21 2020, 05:08 PM
Good job Tom! Now maybe just need carb rebuild or just tuning.
Tdskip |
Jan 21 2020, 05:24 PM
Good job Tom! Now maybe just need carb rebuild or just tuning. @ndfrigi - thanks again for the help and muffler/exhaust. |
Tdskip |
Mar 13 2020, 10:28 PM
Superhawk996 |
Mar 14 2020, 09:22 AM
914 Guru Group: Members Posts: 5,746 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
Tdskip |
Mar 14 2020, 09:33 AM
Going to pull that side head off and start measuring.
Any bets on how big the jugs are. |
914werke |
Mar 14 2020, 11:25 AM
"I got blisters on me fingers" Group: Members Posts: 9,998 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
Are those jugs Alum?
Tdskip |
Mar 15 2020, 06:53 PM
Are those jugs Alum? @914werke - well what do you know, just check with a magnet and they the are aluminum. I am happy about that, correct? |
preach |
Mar 15 2020, 07:36 PM
Ridge Runner Group: Members Posts: 1,028 Joined: 27-March 10 From: Live Free or Die Member No.: 11,513 Region Association: North East States |
Why a "6" on the jug?
Tdskip |
Mar 15 2020, 07:37 PM
Maybe 911?
No idea otherwise. |
Brett W |
Mar 15 2020, 08:05 PM
Could be some Biral cylinders. Probably an iron sleeve pressed into an aluminum cylinder then fins are cut onto the perimeter. 911s used them l ow power applications, maybe slightly better than raw cast iron, but no where near as good as Nickies.
All of the welding on the head is interesting, not exactly sure what they were going to achieve with it. Look forward to more pictures. |
Lo-Fi Version | Time is now: 24th April 2024 - 12:15 AM |
