> Next project, replacing motor and transmission mounts
anderssj
post Jan 18 2020, 10:15 AM
Dog is my copilot...
Hey ya'll! (IMG:style_emoticons/default/bye1.gif)
I'm getting ready to replace the 914's motor and transmission mounts.
I've been researching "how to's" for the motor mounts for a while, and I think I can do this with the engine in the car (Haynes manual confirms this on page 13 as one of the items that "can be attended to with the engine installed." I plan to put car on a lift and support the motor from underneath. Next, remove the shift rod, lower motor mount nuts, and the remove engine mount bar. After that, I should be able to reach up and remove top nuts on motor mounts. I'll be doing an oil change anyway, so the oil filter will be out--hopefully improving access to the top nut on the right-side motor mount.
(Cut to "It could work!" scene in Young Frankenstein).
The transmission mounts should be straightforward, as there are a lot of threads and pictures here in the 914 garage (a GREAT resource). Only question I have (for now) is which mounts to use. There are a few options including:
- 911 convertible engine mounts (PN 911 375 043 07?)
- WEVO mounts (with black/softer cushions)
- 914-4 mount (PN 914 375 025 00) (URO)
- 914-6 mount (PN 914 375 026 00) (URO) (solid rubber)
I was thinking of using the URO 914-6 transmission mounts shown in post 4 here: http://www.914world.com/bbs2/index.php?sho...p;#entry2661903
Has anyone else used URO's -6 transmission mounts? How much stiffer are they compared to the -4 mount? Pelican says that both of the URO pieces come with a 2-year warranty, so that should hopefully cover any problems.
Any tips, BTDTs, observations would be appreciated!
TIA,
Steve A-
GeorgeRud
post Jan 18 2020, 10:38 AM
I used the WEVO trans mounts on my old conversion car, and I thought it helped the shifting by holding the transmission steady and weren’t transmitting too much vibration. The 914-6 trans mounts are stiffer than the ones used in the -4s, so I’d use those as an alternative. Can’t help with the engine mounts.
914Sixer
post Jan 18 2020, 02:45 PM
Get the URO 914-6 mounts. Good product, just like the original including the locking pin in mount.
anderssj
post Jan 20 2020, 08:37 AM
Thanks guys!
Parts on order; should here by this time next week.
All the best,
troth
post Jan 20 2020, 11:01 AM
QUOTE(GeorgeRud @ Jan 18 2020, 12:38 PM) *
I also highly recommend the WEVO trans mounts. I have the blue ones. The difference between those and the 40 year old original ones is night and day. I can upshift much more aggressively and without grinding because the trans is held in place when you take your foot off the accelerator to shift.
JamesM
post Jan 20 2020, 01:51 PM
I have the URO 4 mounts in one of my cars, dont really like them, tranny bounces around pretty bad, I think they may have used a softer rubber than the factory 4 mounts as I swear its worst than some torn stockers i have had. I didnt realize they were making the solid 6 mounts but I would probably start there as 911 motor mounts are not a perfect fit on the 914 trans without some minor modification (though I do run those on most of my cars and they are fantastic)
- Lo-Fi Version Time is now: 13th March 2026 - 09:26 AM
