Maximum Allowable Variance in Deck Height, Stock 2.0 Liter Four |
motorvated |
Jan 18 2020, 10:18 AM
Member Group: Members Posts: 280 Joined: 13-February 13 From: Colorado Member No.: 15,519 Region Association: Rocky Mountains |
I'm in the process of re-assembling the top end of my stock 2.0 liter four, and I have measured deck heights as follows:
#1 - 0.036 #2 - 0.029 #3 - 0.037 #4 - 0.035 These measurements are with the cylinder base sealing rings in place and the cylinders torqued down snugly and measured with a dial gauge. To me it seems as if I need to add a shim to the bottom of cylinder #2 approx. 0.050 - 0.080 to increase its deck height to within the range of the others. I have a couple of used 0.080 shims, one of which I could add to cylinder #2 to bring it up to 0.037. I have a couple of questions about this. First, how much variance is permissible between the measurements? If the deck heights are all within 0.002 of one another, is that Ok or do they need to be exactly the same. Second, can I re-use one of my 0.080 shims or should I source a new one. And third, do I place the shim on top of the cylinder sealing ring, beneath it, or doesn't it matter. I was planning on putting it on top of the sealing ring. Thanks in advance for your advice. |
iankarr |
Jan 18 2020, 10:48 AM
The wrencher formerly known as Cuddy_K Group: Members Posts: 2,473 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region |
I know just enough about engines to get myself in trouble and I’m sure the gurus will reply, but you ideally want the deck height to be consistent. Shims should added To control the compression ratio...not make up differences. |
Lo-Fi Version | Time is now: 20th May 2024 - 08:18 PM |
