General process for restoration 914 |
Stuckon914 |
Jan 18 2020, 12:37 PM
Member Group: Members Posts: 132 Joined: 25-December 18 From: East coast Member No.: 22,747 Region Association: MidAtlantic Region |
I just started restoring my mostly rusty 914/4, 73. I’m looking for parts and a donor car but want to start. Plan is complete tear down and then repair, replace and reassemble. Likely years beginning to end. I took all weather stripping off, carpet and seats out to clean and inspect but need advice in organizing.
For the more experienced what works? Do you start in one area, take everything off, clean, record, label and store away based on section of car? All left door bits go in ‘left door’ tote with each part labeled. Do you track parts working condition or is that more assembly section. I’ve worked on cars before but never to this level of tear down. I’ve searched and got more lost. |
dr914@autoatlanta.com |
Jan 18 2020, 04:47 PM
914 Guru Group: Members Posts: 7,850 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
keep all of the original parts and label very thoroughly
things like "left door panel hardware" right rocker panel hardware right door latch and screws label the switches with the wire color numbers that plug into them the more labeled baggies the better, then put those labeled baggies in a box, for example labeled "door hardware". Or "dashh switches" Put any hardware you can screwed into its original piece, make drawings about how something came apart if difficult ri I just started restoring my mostly rusty 914/4, 73. I’m looking for parts and a donor car but want to start. Plan is complete tear down and then repair, replace and reassemble. Likely years beginning to end. I took all weather stripping off, carpet and seats out to clean and inspect but need advice in organizing. For the more experienced what works? Do you start in one area, take everything off, clean, record, label and store away based on section of car? All left door bits go in ‘left door’ tote with each part labeled. Do you track parts working condition or is that more assembly section. I’ve worked on cars before but never to this level of tear down. I’ve searched and got more lost. |
Lo-Fi Version | Time is now: 12th May 2024 - 01:40 PM |
