Question for an LE owner? Early or late 2.0 plenum on LEs?, which intake/crank case vent system to use? |
JamesM |
Jan 20 2020, 01:26 PM
Senior Member Group: Members Posts: 1,900 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region |
Re assembling a 74 LE Bee from a pile of parts and found the that intake plenum that I got with its original motor is the later style that doesn't use the "F" vacuum connector/has no port of the crank case vent.
My instinct is telling me that this is the wrong part, but i wanted to confirm with another LE owner as to the intake plenum/ crank case vent system used on their LEs. Having noticed other differences between the LE and my earlier 74 car I just want to be absolutely sure before I go and prep another plenum to install. |
JeffBowlsby |
Jan 20 2020, 02:21 PM
914 Wiring Harnesses Group: Members Posts: 8,509 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
Its the standard 2.0L plenum...it requires the F connector. Post photos of what you have?
Attached image(s) |
Lo-Fi Version | Time is now: 17th May 2024 - 06:17 PM |
