Powder coat on Triad muffler |
Olympic 914 |
Jan 20 2020, 03:28 PM
Group: Members Posts: 1,662 Joined: 7-July 11 From: Pittsburgh PA Member No.: 13,287 Region Association: North East States |
Just dropped my muffler off at the local powder coat shop. One guy there expressed concern with the heat and another thought it would be ok.
I don't really know how hot the Triad muffler gets while running. I do have the SS HEs. so some cooling of the exhaust is happening before it gets to the muffler portion. don't have any ceramic coating places around that I am aware of, or I would go that route. Has anyone had their Triad, or other muffler powder coated ? An I just asking for problems here? |
Mark Henry |
Jan 20 2020, 03:31 PM
I had high heat "header" powdercoat done on my bug headers, I don't think it lasted a whole season.
Headers the paint was gone first, 2nd year most of the muffler was bare as well. Have had better luck with BBQ paint. The ceramic like Jet Hot is the best, my MSDS /6 headers are a stained but the coating is standing up real good. |
Nogoodwithusernames |
Jan 20 2020, 03:35 PM
Member Group: Members Posts: 235 Joined: 31-May 16 From: Nor-Cal Member No.: 20,051 Region Association: None |
When I was talking to Dave before ordering mine he said he uses VHT "cast iron" paint. Not sure what your end goal is but that is a proven solution.
Jan 20 2020, 03:37 PM
914-6 GT in waiting Group: Members Posts: 19,238 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Cerikote is the solution.
DRPHIL914 |
Jan 21 2020, 09:10 AM
Dr. Phil Group: Members Posts: 5,758 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
I cleaned mine up and stripped off old stuff and then did high heat primer and high heat silver metallic paint - 2 years ago and so far absolutely no pealing or bubbling- still like I just did it. Takes some work - you could ceramic coat it , Jet Hot Coat or such or what Mark suggested. I did it myself, so far so good
Olympic 914 |
Jan 21 2020, 09:20 AM
I cleaned mine up and stripped off old stuff and then did high heat primer and high heat silver metallic paint - 2 years ago and so far absolutely no pealing or bubbling- still like I just did it. Takes some work - you could ceramic coat it , Jet Hot Coat or such or what Mark suggested. I did it myself, so far so good I was hoping you would chime in. I saw yours and it looked good. I thought you had it ceramic coated. I have used the high heat VHT paint and the back was getting chipped up, probably from the stones hitting it. For now I am going with the high heat powder coat. I originally wanted to do it in a silver color, but they only have the high heat in a satin black. supposed to be good for 800 deg. so that's what I will get. Considered the Jet Hot Coat because of the availability of silver color. That may be an option for another year or so if this doesn't pan out. for now I didn't want to ship out my muffler to have it done. |
VaccaRabite |
Jan 21 2020, 09:28 AM
En Garde! Group: Admin Posts: 13,423 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
powder coat will just melt off. don't bother with it.
Lots of PC shops also do ceramic coating. That IS the way to go. It also keeps most of the heat in the exhaust (pipes don't get as hot, heat goes out the tail pipe). Ceramic is far and away what you want to use. Zach |
DRPHIL914 |
Jan 21 2020, 09:29 AM
This was my second attempt, and has fared better. First time like 5-6 years ago I didn’t prep it and clean it good enough I think. It was a lot of work but results were better. I documented with pics on my rebuild thread. Anyway I found the silver high temp paint at Home Depot and at Autozone.
914_teener |
Jan 21 2020, 06:56 PM
914 Guru Group: Members Posts: 5,194 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
powder coat will just melt off. don't bother with it. Lots of PC shops also do ceramic coating. That IS the way to go. It also keeps most of the heat in the exhaust (pipes don't get as hot, heat goes out the tail pipe). Ceramic is far and away what you want to use. Zach +1 Also....with entropy with an insulating ceramic coating the exhaust will be more efficient. Hot rodders used to wrap the merged collectors with insulating wrap to achieve better flow. |
Lo-Fi Version | Time is now: 25th April 2024 - 08:41 AM |
