Trailing Arm Spherical Bearing |
yeahmag |
Jan 21 2020, 03:25 PM
Advanced Member Group: Members Posts: 2,421 Joined: 18-April 05 From: Pasadena, CA Member No.: 3,946 Region Association: Southern California |
It seems to me that the trailing arms are ripe for a spherical bearing mod. The way the rear toe is set leaves much to be desired, even with (if not more) with Delrin/Teflon bushings.
Has anyone tried to modify the inner ears to allow for a spherical bearing? |
yeahmag |
Jan 21 2020, 04:01 PM
I have the Rebel Racing units and while they are great, I cringe at the idea of running such a small thrust surface as I increase toe in. You can envision how the thrust surface gets smaller and smaller as the angle increases. Now think about the forces I'm putting through it on A7's!
For a long time I thought about self aligning washers (which I use on the RR front teflon bushings for collinearity), but it seems that lots of work would still need to be done to get those to fit. A simple spherical bearing would be an easy fix, especially if someone already has an ovaled out inner ear. |
Lo-Fi Version | Time is now: 18th May 2024 - 05:15 AM |
