Trailing Arm Spherical Bearing |
yeahmag |
Jan 21 2020, 03:25 PM
Advanced Member Group: Members Posts: 2,421 Joined: 18-April 05 From: Pasadena, CA Member No.: 3,946 Region Association: Southern California |
It seems to me that the trailing arms are ripe for a spherical bearing mod. The way the rear toe is set leaves much to be desired, even with (if not more) with Delrin/Teflon bushings.
Has anyone tried to modify the inner ears to allow for a spherical bearing? |
tygaboy |
Jan 21 2020, 04:59 PM
914 Guru Group: Members Posts: 5,292 Joined: 6-October 15 From: Petaluma, CA Member No.: 19,241 Region Association: Northern California |
My buddy Martin was over the other day looking at my Tangerine rear pick up point install and he asked "why don't you add a spherical bearing at the end that "adjusts"?
He used to design and fab ProStock drag bike frames for Kosman so has experience with Harley stuff and he pointed me at the Harley Soft Tail swing arm bearing, of all things. Pictured below. It would require fabbing a "cup" that would weld to the suspension ear, house the bearing and secure it with a circlip. Something to consider, anyway. Attached image(s) |
Jeff Hail |
Jan 21 2020, 10:56 PM
Senior Member Group: Members Posts: 1,141 Joined: 3-May 07 From: LA/ CA Member No.: 7,712 |
My buddy Martin was over the other day looking at my Tangerine rear pick up point install and he asked "why don't you add a spherical bearing at the end that "adjusts"? He used to design and fab ProStock drag bike frames for Kosman so has experience with Harley stuff and he pointed me at the Harley Soft Tail swing arm bearing, of all things. Pictured below. It would require fabbing a "cup" that would weld to the suspension ear, house the bearing and secure it with a circlip. Something to consider, anyway. Why not a bolt on solution that's simple and doesn't have a lot of moving parts? Well at least for the folks that have modified the pickups already. Toe in and toe out on both the inner and outer pivots as well as camber adjustment on both ends. Attached thumbnail(s) |
Lo-Fi Version | Time is now: 18th May 2024 - 05:14 AM |
