Trailing Arm Spherical Bearing |
yeahmag |
Jan 21 2020, 03:25 PM
Advanced Member Group: Members Posts: 2,421 Joined: 18-April 05 From: Pasadena, CA Member No.: 3,946 Region Association: Southern California |
It seems to me that the trailing arms are ripe for a spherical bearing mod. The way the rear toe is set leaves much to be desired, even with (if not more) with Delrin/Teflon bushings.
Has anyone tried to modify the inner ears to allow for a spherical bearing? |
Toby |
May 25 2020, 09:30 PM
Newbie Group: Members Posts: 9 Joined: 22-February 13 From: Rochester, Indiana Member No.: 15,566 Region Association: Upper MidWest |
I'm trying to find the geometry of the rear swing arm and got good info from seeing Jeff Hail's setup. I don't have a 914 but I want to duplicate it's suspension movement, using a bearing and brake from a Pontiac Bonneville SSEi and the drivetrain (mid engine mount).
I'm hoping that you would evaluate the geometry as is for the 914 and make any suggestions for improvement. Questions I have are camber and caster, toe in and out, does the frame mount horizontally or is there a different angle from the plane of the wheels? For a street machine are rubber bushings the way to go or does it need the precision of needle. I've read the above posts and hope you guys will direct me to a thread, if this is not a good place to ask for some engineering help. Thanks |
Lo-Fi Version | Time is now: 18th May 2024 - 03:39 AM |
