Brake Pressure Regulator in Vintage Race Car |
jhynesrockmtn |
Jan 22 2020, 09:17 AM
Member Group: Members Posts: 418 Joined: 13-June 16 From: spokane wa Member No.: 20,100 Region Association: Pacific Northwest |
Hi, I am in the process of refreshing a 914-6 GT tribute car that was built for PCA solo events in CA and has been mostly in storage for several years. The engine is a 2.4 that was built by GD racing in San Bruno. The suspension and brakes are 3.2 Carerra. I pulled the calipers and they are at PMB. New soft lines are going in. I was somewhat surprised to find the stock 914 brake pressure regulator still in place. There is no after market proportioning valve.
The car will be used a few times a year for vintage wheel to wheel and then some PCA DE events. I have several years of experience racing vintage FV. As I got older and saw several buddies get involved in some nasty open wheel tire to tire incidents I decided I wanted fenders and more metal around me. I am not the most aggressive driver in the world and this car will remain street legal. I also want it to remain as period correct as I can get. I don't want to go down the rabbit hole of cutting a ton of metal out of the car, etc. Should I pull the regulator and put a T in and proportioning valve in the cockpit? Should I leave as is and see how it performs? If I leave it I will send to PMB to have them rebuild it. Cheers, Jerry |
ThePaintedMan |
Jan 23 2020, 08:34 AM
Advanced Member Group: Members Posts: 3,886 Joined: 6-September 11 From: St. Petersburg, FL Member No.: 13,527 Region Association: South East States |
I just switched over from the stock limiting valve to an adjustable. After 3 sessions, I finally turned it all the way to the back (at least I think I did) and I still don't feel like I'm getting enough rear pressure. Unfortunately I converted to the BMW calipers on the front a long time ago, which I think is part of the problem. But it did seem to be a stiffer pedal.
However, I don't think you necessarily *have* to eliminate the stock valve, if you don't mind giving up a little braking and pedal feel, especially if you aren't racing ten-tenths. But it's probably a good idea if you want to get the most out of the brakes. |
stownsen914 |
Jan 23 2020, 10:22 AM
The stock valve has a spring loaded mechanism that "absorbs" pressure instead of sending all of it to the rear brakes. I recall in my street 914 that if I stepped hard on the brakes when the engine was off, I could hear the valve actuating and could feel the extra brake pedal travel.
Lo-Fi Version | Time is now: 17th May 2024 - 08:46 PM |
