FS - Dellorto 45 DRLA carb set SOLD |
aircooledtechguy |
Jan 25 2020, 06:43 PM
For sale a matched pair of Dellorto 45mm DRLA carbs. I’ve had these for about 20 years now and never had a motor worthy or that needed these monsters. I've since moved to injection, so these are of no use to me now and must go. These flow almost as much as a Weber 48mm IDF, but in my opinion, are far superior to a Weber with much smoother progression and better flow.
These are dusty from storage over the past 20 years+ and should probably have kits I stalled before use. Otherwise, they are clean and appear to be in excellent condition. The carbs come with the factory velocity stacks and K&N style air cleaners and chromed, embossed Dellorto tops. No linkage or manifolds included. What you see is what you get. Specs are as follows: 45mm throttle sizes 60 idle jets 162 main jets 200 air correction jets 55 pump jets 9164.2 emulsion tubes NOTE: I ONLY ship on Fridays so be aware of that. |
Lo-Fi Version | Time is now: 18th May 2024 - 07:15 AM |
