| Wolfganguntoten |
Jan 28 2020, 07:24 AM
Newbie ![]() Group: Members Posts: 3 Joined: 28-January 20 From: Virginia Member No.: 23,870 Region Association: North East States |
I am looking to drop my stock 73 2.0l and rebuilding it stronger while maintaining day to day driving reliability before putting it back in. Im not interested in blowing the engine by pushing it to its max but Id like to see it reach 115/120 HP without entering the world of the insane. Any help is appreciated. Thank you. (IMG:style_emoticons/default/driving.gif)
| Ian Stott |
Jan 28 2020, 07:33 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 907 Joined: 28-January 08 From: Moncton/Canada Member No.: 8,635 Region Association: Canada |
Check out what is required to have a good reliable 2056, that is what I have and am very happy with the performance. It is not a fire breathing Camaro eating monster,but it certainly get keep up on the spirited driving tours we go on! Many will chime in with in depth descriptions, heads from LN Engineering combined with the proper cam kit from Jake Raby and I have the power and torque range you are looking for. Good luck to you.
Ian Stott Moncton Canada |
| ConeDodger |
Jan 28 2020, 08:45 AM
Apex killer! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,257 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California
2056 - @McMark
| JeffBowlsby |
Jan 28 2020, 09:01 AM
914 Wiring Harnesses & Beekeeper ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,127 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None
Your stated desire to make more power comes at the sacrifice of engine strength. The original stock 1971cc engine was designed with redundancies (safety factors) to handle stresses. Higher displacement, higher compression reduces those safety factors, makes more heat, and may make more HP but the engines components need to become thinner and are higher stressed to accomplish that. So the stock engine becomes inherently weaker to achieve more power. How much so depends on how extreme the mods become. One of several good reasons to leave it stock. You will be wise to avoid the slippery slope. But maybe wise is no fun for some?
| BeatNavy |
Jan 28 2020, 09:18 AM
Certified Professional Scapegoat ![]() ![]() ![]() ![]() Group: Members Posts: 2,956 Joined: 26-February 14 From: Easton, MD Member No.: 17,042 Region Association: MidAtlantic Region
To another Virginian, (IMG:style_emoticons/default/welcome.png) Whereabouts in VA are you?
Jeff is generally a purist about keeping things stock, which is great. However, I think there's a decent consensus that you can meet your stated requirements with the 2056, as others have stated, while still maintaining good reliability and driveability with stock FI components. Do a search on here for 2056 builds. In short, a 2056 is: 1. 96mm pistons and cylinders. These fit in the case with no machining. 2. Stock 71mm crank 3. Cam, and your basic options are: a. stock cam, but that generally won't get you to 110 hp, depending on other specs like compression ratio b. FI compatible cam, like a Type4 Store 9950 or Webcam 73 (I believe), which should get you in that hp range and still give good reliability and driveability with generally stock D-Jet (MPS needs to be tuned) c. Carb-compatible cam. Lots of options, and depending on how aggressive you want to go you can easily meet hp requirements, perhaps at expense of some driveability / idle stability. 2056 is what I have, and lots of others here as well. If you want to deviate from stock and go that route, build it yourself or contact one of the good builders here, like McMark (as Rob suggested). I'm pretty happy with it (IMG:style_emoticons/default/beerchug.gif) |
| Mark Henry |
Jan 28 2020, 12:15 PM
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada |
To another Virginian, (IMG:style_emoticons/default/welcome.png) Whereabouts in VA are you? Jeff is generally a purist about keeping things stock, which is great. However, I think there's a decent consensus that you can meet your stated requirements with the 2056, as others have stated, while still maintaining good reliability and driveability with stock FI components. Do a search on here for 2056 builds. In short, a 2056 is: 1. 96mm pistons and cylinders. These fit in the case with no machining. 2. Stock 71mm crank 3. Cam, and your basic options are: a. stock cam, but that generally won't get you to 110 hp, depending on other specs like compression ratio b. FI compatible cam, like a Type4 Store 9950 or Webcam 73 (I believe), which should get you in that hp range and still give good reliability and driveability with generally stock D-Jet (MPS needs to be tuned) c. Carb-compatible cam. Lots of options, and depending on how aggressive you want to go you can easily meet hp requirements, perhaps at expense of some driveability / idle stability. 2056 is what I have, and lots of others here as well. If you want to deviate from stock and go that route, build it yourself or contact one of the good builders here, like McMark (as Rob suggested). I'm pretty happy with it (IMG:style_emoticons/default/beerchug.gif) (IMG:style_emoticons/default/agree.gif) but will add get European Motor Works (EMW), (4) 96mm Keith Black (KB) pistons, (4) 96mm cylinders, and piston one ring set. That's the way you have to order as EMW has a funny way of ordering. You also want lifters that are matched to the cam. |
| ottox914 |
Jan 28 2020, 08:25 PM
The glory that once was. ![]() ![]() ![]() Group: Members Posts: 1,302 Joined: 15-December 03 From: Mahtomedi, MN Member No.: 1,438 Region Association: Upper MidWest |
2056. See my sig.
| thelogo |
Jan 28 2020, 08:30 PM
Senior Member ![]() ![]() ![]() Group: Retired Members Posts: 1,510 Joined: 6-April 10 Member No.: 11,572 Region Association: None |
To another Virginian, (IMG:style_emoticons/default/welcome.png) Whereabouts in VA are you? Jeff is generally a purist about keeping things stock, which is great. However, I think there's a decent consensus that you can meet your stated requirements with the 2056, as others have stated, while still maintaining good reliability and driveability with stock FI components. Do a search on here for 2056 builds. In short, a 2056 is: 1. 96mm pistons and cylinders. These fit in the case with no machining. 2. Stock 71mm crank 3. Cam, and your basic options are: a. stock cam, but that generally won't get you to 110 hp, depending on other specs like compression ratio b. FI compatible cam, like a Type4 Store 9950 or Webcam 73 (I believe), which should get you in that hp range and still give good reliability and driveability with generally stock D-Jet (MPS needs to be tuned) c. Carb-compatible cam. Lots of options, and depending on how aggressive you want to go you can easily meet hp requirements, perhaps at expense of some driveability / idle stability. 2056 is what I have, and lots of others here as well. If you want to deviate from stock and go that route, build it yourself or contact one of the good builders here, like McMark (as Rob suggested). I'm pretty happy with it (IMG:style_emoticons/default/beerchug.gif) (IMG:style_emoticons/default/agree.gif) but will add get European Motor Works (EMW), (4) 96mm Keith Black (KB) pistons, (4) 96mm cylinders, and piston one ring set. That's the way you have to order as EMW has a funny way of ordering. You also want lifters that are matched to the cam. (IMG:style_emoticons/default/agree.gif) Thats the stuff they built my big /4 with ... (IMG:style_emoticons/default/aktion035.gif) |
Lo-Fi Version | Time is now: 6th December 2025 - 12:04 AM |
