| Wolfganguntoten |
Jan 28 2020, 07:24 AM
Newbie ![]() Group: Members Posts: 3 Joined: 28-January 20 From: Virginia Member No.: 23,870 Region Association: North East States |
I am looking to drop my stock 73 2.0l and rebuilding it stronger while maintaining day to day driving reliability before putting it back in. Im not interested in blowing the engine by pushing it to its max but Id like to see it reach 115/120 HP without entering the world of the insane. Any help is appreciated. Thank you. (IMG:style_emoticons/default/driving.gif)
| BeatNavy |
Jan 28 2020, 09:18 AM
Certified Professional Scapegoat ![]() ![]() ![]() ![]() Group: Members Posts: 2,960 Joined: 26-February 14 From: Easton, MD Member No.: 17,042 Region Association: MidAtlantic Region
To another Virginian, (IMG:style_emoticons/default/welcome.png) Whereabouts in VA are you?
Jeff is generally a purist about keeping things stock, which is great. However, I think there's a decent consensus that you can meet your stated requirements with the 2056, as others have stated, while still maintaining good reliability and driveability with stock FI components. Do a search on here for 2056 builds. In short, a 2056 is: 1. 96mm pistons and cylinders. These fit in the case with no machining. 2. Stock 71mm crank 3. Cam, and your basic options are: a. stock cam, but that generally won't get you to 110 hp, depending on other specs like compression ratio b. FI compatible cam, like a Type4 Store 9950 or Webcam 73 (I believe), which should get you in that hp range and still give good reliability and driveability with generally stock D-Jet (MPS needs to be tuned) c. Carb-compatible cam. Lots of options, and depending on how aggressive you want to go you can easily meet hp requirements, perhaps at expense of some driveability / idle stability. 2056 is what I have, and lots of others here as well. If you want to deviate from stock and go that route, build it yourself or contact one of the good builders here, like McMark (as Rob suggested). I'm pretty happy with it (IMG:style_emoticons/default/beerchug.gif) |
| Mark Henry |
Jan 28 2020, 12:15 PM
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada |
To another Virginian, (IMG:style_emoticons/default/welcome.png) Whereabouts in VA are you? Jeff is generally a purist about keeping things stock, which is great. However, I think there's a decent consensus that you can meet your stated requirements with the 2056, as others have stated, while still maintaining good reliability and driveability with stock FI components. Do a search on here for 2056 builds. In short, a 2056 is: 1. 96mm pistons and cylinders. These fit in the case with no machining. 2. Stock 71mm crank 3. Cam, and your basic options are: a. stock cam, but that generally won't get you to 110 hp, depending on other specs like compression ratio b. FI compatible cam, like a Type4 Store 9950 or Webcam 73 (I believe), which should get you in that hp range and still give good reliability and driveability with generally stock D-Jet (MPS needs to be tuned) c. Carb-compatible cam. Lots of options, and depending on how aggressive you want to go you can easily meet hp requirements, perhaps at expense of some driveability / idle stability. 2056 is what I have, and lots of others here as well. If you want to deviate from stock and go that route, build it yourself or contact one of the good builders here, like McMark (as Rob suggested). I'm pretty happy with it (IMG:style_emoticons/default/beerchug.gif) (IMG:style_emoticons/default/agree.gif) but will add get European Motor Works (EMW), (4) 96mm Keith Black (KB) pistons, (4) 96mm cylinders, and piston one ring set. That's the way you have to order as EMW has a funny way of ordering. You also want lifters that are matched to the cam. |
Wolfganguntoten 914/4 2.0l best build for stock engine Jan 28 2020, 07:24 AM
Ian Stott Check out what is required to have a good reliable... Jan 28 2020, 07:33 AM
ConeDodger 2056 - @McMark Jan 28 2020, 08:45 AM
JeffBowlsby Your stated desire to make more power comes at the... Jan 28 2020, 09:01 AM
thelogo
To another Virginian, :wttc: Whereabouts in V... Jan 28 2020, 08:30 PM
ottox914 2056. See my sig. Jan 28 2020, 08:25 PM![]() ![]() |
Lo-Fi Version | Time is now: 11th March 2026 - 12:52 AM |
