How to grind/dress magnesium, ...safely |
TargaToy |
Feb 4 2020, 03:59 PM
-NONSOLIS RADIOS SEDIOUIS FULMINA MITTO- Group: Members Posts: 692 Joined: 26-March 10 From: DelMarVa Peninsula Member No.: 11,509 Region Association: MidAtlantic Region |
I've seen pics today of members' cleaned up/polished transaxles and noticed that the casting flashing has been removed in some instances--giving a much cleaner look.
I know that magnesium is volatile in that grinding or cutting, creating too much heat, can cause a flash fire. What's the best, SAFEST, way to remove flashing from the housing? |
burton73 |
Feb 4 2020, 04:29 PM
burton73 Group: Members Posts: 3,524 Joined: 2-January 07 From: Los Angeles Member No.: 7,414 Region Association: Southern California |
As nice as Dicks transmission looks in the pictures it will roll back to a nice grey color after some time. It may take a year or more to do that but it will. I had a Magnesium 5 lug Gas Burner polished to a chrome look to see how it would age. After some time, it got a milky white coating on it. I decided that the other 4 wheels should just be painted in silver like the wheels from the factory.
There have been a lot of 914 articles on Mag and painting it. I do know of a magnesium small fire that happened at Bieker Eng. in the late 70s but it was put out with the right fire extinguishers (Class D fire extinguishers are used on combustible metals. These include magnesium, sodium, aluminum, and titanium) This was from machining a Eng. case In high school the teacher in Science burned some Mag ribbon. Super bright. Use a small die grinder and take at easy but why bother. The wire wheel like Dick used will give you that look and that is much better than paint. Eric restored my 914 trans on 41 with Walnut shells I think it Looked good and was realistic of what these old funky looking cases can look like. Sorry I do not have a picture handy Bob B (IMG:style_emoticons/default/idea.gif) |
Feb 4 2020, 05:42 PM
Mag is very reactive. If you want it to stay pretty, you have to paint it.
TargaToy |
Feb 4 2020, 05:57 PM
I’m fine with paint but was just thinking that, like engine blocks I’ve painted in the past, the finish looks better when the sharp edges and casting marks are knocked down first.
And honestly, I don’t care that much about a show car undercarriage, but the side shifter I picked up to rebuild had a bit of a texture to it when I did the initial degreasing. It looks like it would resist goop and grime better if the surface was smoothed and/or sealed a bit. |
Feb 4 2020, 06:57 PM
I’m fine with paint but was just thinking that, like engine blocks I’ve painted in the past, the finish looks better when the sharp edges and casting marks are knocked down first. And honestly, I don’t care that much about a show car undercarriage, but the side shifter I picked up to rebuild had a bit of a texture to it when I did the initial degreasing. It looks like it would resist goop and grime better if the surface was smoothed and/or sealed a bit. McMark has epoxy painted them and Ben used Cerikote. - http://www.914world.com/bbs2/index.php?sho...39&hl=epoxy Attached image(s) |
DickSteinkamp |
Feb 4 2020, 06:58 PM
Senior Member Group: Members Posts: 500 Joined: 27-February 17 From: Bellingham, WA Member No.: 20,876 Region Association: None |
My case that i pictured was not ground any...just the fine wire wheel.
I agree that the shine will not last long. I think a year is generous. It's just that I'm a little OCD. (IMG:style_emoticons/default/smile.gif) |
Feb 4 2020, 07:03 PM
My case that i pictured was not ground any...just the fine wire wheel. I agree that the shine will not last long. I think a year is generous. It's just that I'm a little OCD. (IMG:style_emoticons/default/smile.gif) I vapor blasted a mag trans. It looked almost like aluminum for a while and then oxidized to grey. |
914_teener |
Feb 4 2020, 07:14 PM
914 Guru Group: Members Posts: 5,198 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
Exothermic Cerikote or leave it alone.
It gets hot. |
TargaToy |
Feb 4 2020, 07:37 PM
Cerakote? As used in the firearms industry? Now THAT’s an interesting idea!
Feb 4 2020, 07:55 PM
914forme |
Feb 4 2020, 08:57 PM
Cerakote? As used in the firearms industry? Now THAT’s an interesting idea! YEs, it is used on a lot more stuff than just firearms (IMG:style_emoticons/default/shades.gif) |
Lo-Fi Version | Time is now: 16th May 2024 - 07:27 PM |
