groot |
Dis member ![]() ![]() ![]() Group: Members Posts: 896 Joined: 17-December 03 From: Michigan Member No.: 1,444 ![]() |
BTW.. Jake, what deck height should I be shooting for? 0.035"
Jake Raby |
Engine Surgeon ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,394 Joined: 31-August 03 From: Lost Member No.: 1,095 Region Association: South East States ![]() |
yep, run .035- You need all the compression you can get.
BTW- have you been data logging EGT? If so I'd like to see what you had EGT wise with the old combo to see if you were running it slightly retarded with the high octane. This way I may be able to crunch some numbers and start you out at a better base line for timing advance this time.. |
groot |
Sorry, no logging of the EGTs. I don't have enough channels for 4 EGTs.
ChrisFoley |
I am Tangerine Racing ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,937 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None ![]() ![]() |
Webers? Where did you get 36mm vents? (I have sets for sale, on the shelf.) |
groot |
I'm running Dells. Ordered the parts from Italy.
Your vents are too expensive for me (IMG:http://www.914world.com/bbs2/html/emoticons/sad.gif) |
Lo-Fi Version | Time is now: 16th June 2024 - 09:41 AM |
