Bright work, Hhhhmmm, these are tough to clean! |
ctc911ctc |
Feb 4 2020, 05:26 PM
Senior Member Group: Members Posts: 892 Joined: 9-June 18 From: boston Member No.: 22,206 Region Association: North East States |
All,
Our daily driver 914 is back on the road running great - with the new paint, I would like to brighten up the brightwork. I started the path as to sanding with a 400 and working my way to the 1500.....this might take forever! Here are a few of the windscreen pieces. Here are some examples of the state of the aluminum, what is the best way to get this stuff brightened up? Thank you Teeners |
ConeDodger |
Feb 4 2020, 05:33 PM
Apex killer! Group: Members Posts: 23,588 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
It’s anodized. There are people who will do it for you. First you clean it up by sanding it with very fine paper then polish, then anodize...
Feb 4 2020, 05:51 PM
(IMG:style_emoticons/default/agree.gif) if you just sand and polish, it will dull quickly.
By the time you ship to a place to restore it, pay them and then ship back, you might as well buy new. |
ctc911ctc |
Feb 4 2020, 07:57 PM
Powder coat?
rhodyguy |
Feb 4 2020, 09:32 PM
'Chrome' paint at this point or as suggested new. No point in springing for 2x shp and refinish unless they're absolutely perfect. Not to mention the time factor.
Mikey914 |
Feb 5 2020, 02:19 AM
The rubber man Group: Members Posts: 12,668 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Sad to say but the anodizing makes it way too difficult. Honestly, if you strip and polish, you can just keep polishing.
dt4 |
Feb 5 2020, 02:25 AM
Senior Member Group: Members Posts: 503 Joined: 26-May 19 From: England Member No.: 23,161 Region Association: England |
I found a place local to me (lots of metal finishers in the back streets of UK towns) and had the windscreen trim and sail panel trim striped and polished plus a few other parts stripped and chromed for £250
I wouldn't try shipping the windscreen trim over here, our couriers would fold it like origami to make it easier to handle |
dcheek |
Feb 5 2020, 06:34 AM
Senior Member Group: Members Posts: 691 Joined: 30-May 06 From: Westfield, New Jersey Member No.: 6,103 |
live free & drive |
Feb 5 2020, 01:24 PM
Member Group: Members Posts: 158 Joined: 29-June 16 From: New Hampshire Member No.: 20,159 Region Association: None |
You're in Boston so drop it off to Sean at Tru-6 in Watertown - check out his work:
http://tru-6.com/anodizing-2 |
Feb 5 2020, 01:34 PM
You're in Boston so drop it off to Sean at Tru-6 in Watertown - check out his work: http://tru-6.com/anodizing-2 He does great work. |
Sway Bar |
Feb 5 2020, 01:57 PM
Member Group: Members Posts: 88 Joined: 17-December 19 From: Okanagan Valley, Great White North Member No.: 23,743 Region Association: None |
If one is adamant of doing the DIY method...the secret is to remove the anodizing first with oven cleaner. Needs to be the Easy off Yellow can version. It will eat the anodizing via a few applications and time and then you can proceed via 400-600, etc grits and then eventually aluminum polish. I have done this on window trims/frames/wheels, namely because up here in the north we can't find anyone to do such work and all the chemicals are outlawed, shipping suxs etc. etc.
Need to remember you now have bare soft aluminum and it won't have the hard finish. Lots of elbow grease and time....so if you can, send it out, I would. |
dt4 |
Feb 5 2020, 02:19 PM
If one is adamant of doing the DIY method...the secret is to remove the anodizing first with oven cleaner. Needs to be the Easy off Yellow can version. It will eat the anodizing via a few applications and time and then you can proceed via 400-600, etc grits and then eventually aluminum polish. I have done this on window trims/frames/wheels, namely because up here in the north we can't find anyone to do such work and all the chemicals are outlawed, shipping suxs etc. etc. Need to remember you now have bare soft aluminum and it won't have the hard finish. Lots of elbow grease and time....so if you can, send it out, I would. good point the place I used wouldnt touch the PORSCHE letters because they were "monkey metal" and too fiddly to polish I stripped the anodising with oven cleaner and then fixed them to a board to make them easier to polish and then polished them with autosol metal polish and a fibre pad with a dremel multi tool |
ctc911ctc |
Feb 5 2020, 03:36 PM
DANG
Just dropped them at a powder coat place in the Watertown area - had no idea about True6, sorry. The shop I went to is https://pikepowdercoating.com/ They did my headlight frames and did a great job. Not sure I want the CHROME look. they are going to remove the anodize coat polish and recoat with a clear non-yellowing product. About 175 for the windshield frame, going to start there. Thanks to ALL TEENERS! |
TargaToy |
Feb 5 2020, 03:48 PM
-NONSOLIS RADIOS SEDIOUIS FULMINA MITTO- Group: Members Posts: 692 Joined: 26-March 10 From: DelMarVa Peninsula Member No.: 11,509 Region Association: MidAtlantic Region |
I haven't tried this on any of the 914 trim but I usually shine up aluminum bits with a high-speed buffing wheel on my bench grinder and some polishing rouge. Not only does that make pretty quick and uniform work, but there aren't sanding grooves. The speed of the wheel seems to "seal" the pores in the aluminum, making periodic maintenance pretty easy after that.
I have an aluminum exhaust canister on my motorcycle that I gave a good shine with the method above and I just have to hit it with some Mother's metal polish by hand about once a year and it takes relatively little time. The oxidation just buffs off on the cloth. |
dr914@autoatlanta.com |
Feb 5 2020, 03:55 PM
914 Guru Group: Members Posts: 7,864 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
Al Reed in california can reanodize them
All, Our daily driver 914 is back on the road running great - with the new paint, I would like to brighten up the brightwork. I started the path as to sanding with a 400 and working my way to the 1500.....this might take forever! Here are a few of the windscreen pieces. Here are some examples of the state of the aluminum, what is the best way to get this stuff brightened up? Thank you Teeners |
nihil44 |
Feb 5 2020, 04:16 PM
Member Group: Members Posts: 157 Joined: 28-January 12 From: Brisbane, Australia Member No.: 14,058 Region Association: None |
I would be wary of using oven cleaner on aluminium. Most oven cleaners that are effective are caustic soda (sodium hydroxide) based or other similar strong alkaline salts. They usually have a warning not to use them on aluminium components
You probably remember the high school chemistry experiment of producing hydrogen by putting aluminium in a solution of caustic soda. I would hate to see our 914 unobtanium components going up to the sky as hydrogen. I would endorse the advice to have the components refinished by a reputable anodiser. In my city they are not all reputable |
Lo-Fi Version | Time is now: 17th May 2024 - 11:53 AM |
