1974 914 Rust Repair Project |
sreyemj |
Feb 7 2020, 04:14 PM
Member Group: Members Posts: 87 Joined: 12-January 20 From: SA, TX Member No.: 23,821 Region Association: None |
This will be an attempt to document a long and sordid history of my 1974 1.8L 914. It's been with me a long time, and suffered many ills both before and during my ownership.
My initial interest in Porsches came after reading "Porsches For The Road" as a young child, I still have the book! (IMG:http://www.914world.com/bbs2/uploads_offsite/i.imgur.com-23821-1581114089.1.jpg) I really wanted a 911 or 912, but even project cars were beyond my budget of about 2k. I thought I had it made when our elderly neighbor parked a neglected yellow 1984 911 Targa under a tarp in the alley between our houses. He didn't want to sell it, but I used to keep the tarp tied down in the hopes I could one day purchase it. Unfortunately, we never made a deal and when he died several years later the car disappeared. After that, I started shopping for 914s, and this 1974 914 car popped up for $800 on craigslist. It was garaged, had awful brown paint, and the passenger door closed nicely. The seller mentioned he wasn't the original owner and that he parked it when the motor became "tired" in the mid 1990s. A deal was made, and I brought it home in a torrential downpour. I was about 15 years old at this point. First restoration efforts (2007ish): My first attempt at getting the 914 back on the road included painting it a red I picked out of the Sherwin-Williams catalog instead of the original Marathon Blue Metallic (unfortunately!). Upon further investigation, there were some pin holes in the bottom of the passenger long as well as some small holes under the battery tray. The door closed fine and it didn't look like the really ugly pictures I had seen, so I figured it was at least structurally sound. I remember pouring a rust converter into the small holes under the battery, then welding a plate over the top. There were some holes in the rear trunk, so I cut that metal out and welded sheet metal in. The bottom of the passenger long looked fine, so I left that as is. 15 year old me was not a talented welder. While removing the paint, I discovered the car had been in an accident, and that the driver's front fender/headlight cavity were not-so-artfully grafted on from another car. I also found accident damage on the passenger rear quarter panel and rear trunk. The seller did not admit to any accidents, so I assume these are from a previous owner. After painting, I never really put it back together and the car sat for about a decade. During this time I was off at college, then the military, and then more school. My younger brother wanted to use it as a getaway car at his wedding, and almost completely reassembled it with a 1.7L engine I had purchased from a guy doing a V8 swap. I sold the original 1.8L during one of several moves over the years… I drove the car exactly once with the 1.7L engine, I remember it ran poorly with high idle and leaked a fair amount of oil. Getting started, one of the only early pictures of the car: (IMG:http://www.914world.com/bbs2/uploads_offsite/i.imgur.com-23821-1587745562.1.jpg) Car after painting (side skirts never made it on): (IMG:http://www.914world.com/bbs2/uploads_offsite/i.imgur.com-23821-1581113671.1.jpg) Second attempt (2020ish): It had been almost 15 years since I bought the car. I had moved many times for school, military, more school, and then more military. The car mostly lived at my dad’s house during this time, but I now had a small garage I could park it in. I brought it home and got to work. It quickly became obvious (thanks to browsing 914world!) that the rust problems were not minor, and would require significant work to repair before anything else. I decided to move front to back. The bottom of the car was coated with a thick bed-liner type coating that I removed from the bottom of the floor pans and much of the front trunk. You can see some of the original paint in the wheel well where the coating was removed with a putty knife. As it sits today: (IMG:http://www.914world.com/bbs2/uploads_offsite/i.imgur.com-23821-1581113672.2.jpg) Passenger long, looks fairly solid from the outside. The hole is where I used a cheap endoscope to look at the inside (lots of rust). (IMG:http://www.914world.com/bbs2/uploads_offsite/i.imgur.com-23821-1581114160.1.jpg) The 1.7L motor. Not sure why it's blue, definitely needs some help. (IMG:http://www.914world.com/bbs2/uploads_offsite/i.imgur.com-23821-1581114090.3.jpg) |
sreyemj |
Mar 30 2020, 10:47 PM
I removed the interior so I could weld my door braces on, and made an interesting discovery. It looks like someone has cut into the inside long and stuffed it full of fiberglass insulation? There are aluminum covers pop-riveted over the large round holes as well as duct tape and some duct tape inside the long on the heating tube.
Trying to decide what to do with this. I can access the inside of the long from these holes and probably knock off most of the rust with a die grinder. I was going to use the 914 LTD reinforcement kit (already purchased), but the inner long reinforcement kit would cover this area nicely. I'm also curious if treating this rust inside the long with Ospho would be sufficient. The outside looks ok, and I'm not sure I'll gain much by opening it up. The metal covers: (IMG:http://www.914world.com/bbs2/uploads_offsite/i.imgur.com-23821-1585630037.1.jpg) The holes and insulation: (IMG:http://www.914world.com/bbs2/uploads_offsite/i.imgur.com-23821-1585630193.1.jpg) Outside of the long: (IMG:http://www.914world.com/bbs2/uploads_offsite/i.imgur.com-23821-1585630259.1.jpg) Loose rust inside the long, doesn't look too bad: (IMG:http://www.914world.com/bbs2/uploads_offsite/i.imgur.com-23821-1585630038.3.jpg) |
Superhawk996 |
Apr 1 2020, 06:14 AM
914 Guru Group: Members Posts: 5,819 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
It looks like someone has cut into the inside long and stuffed it full of fiberglass insulation? (IMG:style_emoticons/default/WTF.gif) The stuff previous owners did to these cars never ceases to amaze me. (IMG:style_emoticons/default/lol-2.gif) If there is a competiton for most abused model of cars, 914's surely must be near the top of the list. I know you probably don't want to hear this but you really should open it up and just do it right once and for all. I see pin holes on the outer long. That means the inner is side of the outer longitudinal has been rusting from the inside outward. You can put the LTD long kit over that but you'll basically be covering over the lower portion of the rusted long outer. You look like you have the skills to do it right. With that level of rust and previous owner damage to the inner long you really would do well to just fix it right. That inner long is what the seat belt attaches to. That big hole cut above the seat belt anchor is dangerous and will lead to the anchor just tearing out if it were in an impact. The C-shape section of the long inner is where much of the structural strength comes from. Once that C section is closed out by the long outer you have a box section that is quite stiff and is the main structural element. You most definately don't want a lack of metal integrity there. I feel your pain and the desire to do it as quickly as possible and potentially with the LTD, or Engman inner long type kits. I had very similar challenges on my car upon discovering that the longitudinal rust was more extensive than I had hoped when 1st bought the car but my car is certainly worse than where you're starting from. |
sreyemj |
Apr 1 2020, 10:51 AM
Lo-Fi Version | Time is now: 16th May 2024 - 02:15 AM |
