914/6 GT Cibie Spotlight mount fab, winter project |
Retroracer |
Feb 7 2020, 07:24 PM
Senior Member Group: Members Posts: 612 Joined: 7-July 13 From: Bend OR Member No.: 16,100 Region Association: Pacific Northwest |
I’ve always been fascinated by the front lower spotlight mounting that appears on some of the GT cars, notably the winning 1970 Marathon de la Route cars. A few years ago I got a chance to obtain some original Cibie Iode 45 lamps from a seller in France. These had yellow lenses – one fog, one driving - which matched the yellow Cibie Tango’s I have mounted in my GT tribute car already, in the “standard” fog light position within the fiberglass front bumper. Not clear to me was how the factory fabricated brackets were designed. The inverted “T” cut into the fiberglass bumper meant that the brackets must somehow get fed through that to get mounted; also somehow they mount to the body and may / may not hold the bumper on? Searching in-period as well as recent pictures did not yield many clues; a few detailed the outside construction and bracing, but I had no clear idea of what was behind the bumper cut out. Until: luckily last summer I did get a chance to see the original “Number 2” Marathon car up close at Luft 6, so took the opportunity to crawl around under the front of the car to try and see what was going on. That is, until folks who were waiting to take unobstructed pictures of the legendary vehicle were bored of waiting for the strange geezer lying on his back peering into the oil cooler opening….! I took some detailed pics and thought that attempting to make up some brackets might be a good winter project. It is not clear to me (on olde number 2) whether the brackets were the originals or replicas – but I learned enough to want to try and replicate them. So the brackets themselves (as the pics show) look pretty basic on the face of it. But some thought obviously went into the design, as they need to meet multiple criteria: - be shaped such that they can be fed through the inverted “T” cut in the bumper - secure the bumper to the body - have welded in bracing to prevent the lights vibrating & flexing - clear the front valance mounting tabs (which are just below the bumper mount holes) The upper piece in this shot shows the side profile I went for, bent up in aluminum as a test for clearance; one of the main bracket is being fab'ed using mild steel. The cut in the bumper (fiberglass) was done with fingers crossed but turned out to be correct, the shot below shows a test fit & alignment check before cutting the vertical: I welded some M6 nuts to the strips to use as mounts, aligned with the holes in the bumper and the body. Cutting the bracing pieces needed some experimentation and mocking up, as looking carefully at the existing photos of the OUTSIDE, it was hard to judge overall dimensions – extension, drop, etc. – so in the end it was basically a visual judgement call. and.... |
914forme |
Sep 14 2020, 08:42 AM
Alpha test unit, this was mocked up, I need to grab a set of Cibi Oscars. That Hella looks out of place with the other lights.
Have a few changes to make. And an idea to make it easier to hold onto the bumper mount to make installation a bit less of a hassle. Right now you need at least 3 hands, in my case, two hands and a leg. But here it is, the cost will be based of final material choice, an TIG weld time. Lots of little dimes to be added (IMG:style_emoticons/default/blink.gif) And I found out an interesting item on my -6 the bumper was being held on by friction and gravity. No nuts on the inside of the bracket. That is the reason for the large clamp in the picture. I added a few holes to allow for better wire management. The hole that the two wires drop into will be upsized for a grommet and the grommets will be included in the kit. There is a set of rear holes that can be used for a zip tie to hold the wires close to the brake to get them behind the bumper. Also note the Alpha Prototype was made out of mild steel, no welding was done yet. Metal is strong enough to hold the weight with just the physical bends. I will weld it and do a stress test at a latter date to failure. As I said I have a couple of changes I need to make to the design, and it will be ready for production. Want to test fitment with a Set of Cibie Oscars, and Cibie LED Oscars. As I think the back space will be different for each. These can be made out of various metals, I laser cut these. Mild Steel $$ Stainless Steel $$.$ Titanium $$$ roughly 4x the price, but would be (IMG:style_emoticons/default/drooley.gif) |
Lo-Fi Version | Time is now: 11th May 2024 - 07:22 AM |
