for sale - Selling all my 914 stuff |
S Florida V8 |
Feb 11 2020, 12:59 PM
I'm new here ... Group: Members Posts: 0 Joined: 11-February 20 From: South Florida Member No.: 23,914 Region Association: None |
I can supply pictures of any and all items listed below:
These parts were for a V8 project car that I never completed. Got distracted on other projects... All are available for someone to come inspect if desired. Was going to keep it all around but have lost my storage space and frankly I'm coming to realize that after 3 back surgeries I'm never going to get around to doing anything with these. I'm located at the north end of Broward County Florida. Comlpete front suspension with new Koni shocks (new) but have been sitting installed in the struts for 10 years - never used. Has new ground control torsion bars (well they've been sitting in the front end for 10 or so years but never used) with new bushings. Has steering rack installed on steel crossmember from older 911. It has five lug front hubs with big four piston Brembos from Porsche 928 S front. I would sell this complete front suspension for $1,000 or best offer. Would probably need to pick it up locally because with the big front rotors etc. It's fairly heavy. has some light surface rust on some of the parts but easy clean up. Also have a 930 turbo transmission that has been completely rebuilt by Vertex in Miami. I had them flip the ring and pinion so it doesn't need to run upside down. This thing is a beast! Flipping the ring and pinion is not a bolt in...It's a TON of work. This can handle TONS of torque! I also have the Porsche 930 axles to go with it (remember this was for a V8 conversion) This was about $5K of transmission 12 years ago. I would let this go for $2,500... This would come with a custom V8 engine cradle that mounts the V8 and trans (bolts front and rear to 914 stock engine and transmission mount locations (trick setup). Unit comes with Kennedy adapter nd clutch for small block chevy. I also have a compete sheridan body kit. It was installed on a 914 but I cut it back off when I sold the 914 shell about 2 years ago.This is the standard (not extra wide) body kit. It was cut off with some of the aged 914 panels it was bonded to still attached around the edges but hey, it's fiberglass, easy to clean up and install. $800. Would have to think about shipping? Front trunk lid (carbon fiber) but it has been primed over (the carbon look was never my thing... $150.00 Rear trunk lid with ducktail spoiler incorporated into it. (also carbon fiber but primed over as above). $150 Two rear trailing arms that are older 911 steel trailing arms welded into the 914 trailing arms to give about 3 inches of lowering at the normal position/angle of the 914 arms. These also have the five lug hubs of course with rotors and Brembos from rear of 928 S $500? two new Koni shocks with adjustable spring perch's, including springs for rear. price? or come get the whole schmeer and i'll make a good deal on all of it.. if you want to take a look let me know.... I also have a complete (I mean compete) front suspension from a Boxster S and a complete rear suspension from a Boxster S along with the Boxster six speed transmission mounted. I had thought bout putting all of this in a 914 also... If you want me to take pictures and post them here let me know... |
Chi-town |
Feb 14 2020, 09:58 AM
Senior Member Group: Members Posts: 850 Joined: 31-August 18 From: Disneyland Member No.: 22,446 Region Association: Southern California |
Let me know a price on all the boxster S stuff. If you can toss it all on one pallet I'm interested.
S Florida V8 |
Feb 15 2020, 08:30 AM
Let me know a price on all the boxster S stuff. If you can toss it all on one pallet I'm interested. Are you talking about the complete front and rear suspension with Transmission? It would be front crossmember with both front suspension corners. including the adjustable Bilstien PSS9 shocks, two piece GT3 lower control arms, Steering rack and four piston brembos with Hawk brake pads, front anti roll bar and lightly used front rotors. Also complete (totally complete) rear suspension with GT3 lower control arms, Tarrett adjustable toe links, Bilstien PSS9 rear shocks, all crossmembers, drag links, rear anti roll bar, four piston brembo calipers (as above) lightly used rotors etc. Also Boxster 6 speed transmission including slave cylinder and transmission mounts/brackets that bolt tranny into rear suspension... These would also include all the specialty bolts and nuts that locate and attach the front and rear suspensions. If these are going into a Boxster, you just bolt them all on and go.. If you are grafting them onto something else I can cut the body parts off the Boxster shell (where they mount) and send those pieces of the shell with the parts If so then I will PM you a price. And any pictures you want... I also have all three front radiators with fans, shrouds and ducts. These would also include the A/C condensers. I also have two complete sets of wheels with junk tires on them. One set of Boxster S wheels and one set of "18 repro "cup" wheels. Let me know exactly which pieces you are interested in and I'll PM you a quote. I'm sure I could condense these parts and put as many as you are interested in on a single pallet. |
Lo-Fi Version | Time is now: 17th May 2024 - 07:41 AM |
