Torque settings? |
Torque settings? |
Robson51 |
Feb 13 2020, 05:09 PM
Member Group: Members Posts: 88 Joined: 18-November 19 From: seattle Member No.: 23,654 Region Association: Pacific Northwest |
I've used the search settings and also googled this question. Searching this site produced nothing and Google gives more than one answer.
What is the torque wrench setting for the intake manifold nuts? I have seen numbers from 4 (!) to 10 ft lbs. What is the torque setting for the rocker arms? Again, a couple different numbers but 14 ft lbs seems the middle. Any advice here? Thanks Rob |
iankarr |
Feb 14 2020, 09:19 AM
The wrencher formerly known as Cuddy_K Group: Members Posts: 2,472 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region |
The Haynes manual has a lot of torque values at the beginning of each section. For 8.8 grade M8, the standard torque is 17 ft-lbs.
Robson51 |
Feb 14 2020, 10:45 AM
The Haynes manual has a lot of torque values at the beginning of each section. For 8.8 grade M8, the standard torque is 17 ft-lbs. I would think the intake manifold nuts were in that range, but Haynes calls out for 4.35 ft lbs. I've never seen that low of a setting on such a big bolt and can't figure out the logic behind it. Is it a typo? Can someone explain why it would be so low? |
Lo-Fi Version | Time is now: 6th May 2024 - 09:41 AM |
