Torque settings? |
Torque settings? |
Robson51 |
Feb 13 2020, 05:09 PM
Member Group: Members Posts: 88 Joined: 18-November 19 From: seattle Member No.: 23,654 Region Association: Pacific Northwest |
I've used the search settings and also googled this question. Searching this site produced nothing and Google gives more than one answer.
What is the torque wrench setting for the intake manifold nuts? I have seen numbers from 4 (!) to 10 ft lbs. What is the torque setting for the rocker arms? Again, a couple different numbers but 14 ft lbs seems the middle. Any advice here? Thanks Rob |
rhodyguy |
Feb 14 2020, 11:04 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,072 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
Value is based on the stud size. Not the nut.
Robson51 |
Feb 14 2020, 11:16 AM
ClayPerrine |
Jan 19 2021, 07:38 AM
Life's been good to me so far..... Group: Admin Posts: 15,439 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
Value is based on the stud size. Not the nut. I get that, but again-why 4 ft lbs on an 8MM stud? Torque settings for air cooled motors are much lower than their water cooled counterparts because air cooled motors grow when they get hot. So the torque on all the bolts go up as the engine warms. 4ft lbs is probably enough on the intake bolts. They are not structural, and the engineers don't want to crush the gasket when the engine is fully warm. |
Lo-Fi Version | Time is now: 6th May 2024 - 08:11 AM |
