WTB: Temp Sensor for Cold Start Valve, Thermo Time Switch Part # 311 906 161C |
stevend914 |
Feb 14 2020, 12:11 PM
Member Group: Members Posts: 376 Joined: 13-December 16 From: Saint Louis Member No.: 20,670 Region Association: Upper MidWest |
Or any suggestion on where to look, I've tried searching with no luck.
914Sixer |
Feb 14 2020, 02:47 PM
914 Guru Group: Members Posts: 8,863 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
I had one but I may have sold it. Have to look.
914Sixer |
Feb 16 2020, 05:54 AM
Sold it.
bdstone914 |
Feb 16 2020, 10:39 AM
bdstone914 Group: Members Posts: 4,508 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
@stevend914
Or any suggestion on where to look, I've tried searching with no luck. [/quote] I have some. $25 ,shipped. Bruce Attached thumbnail(s) |
GregAmy |
Feb 16 2020, 11:10 AM
Advanced Member Group: Members Posts: 2,264 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States |
Doesn't hurt to have it working (and at $25 shipped that's cheap), but do you really need it? The CSV valve only comes on if the temperature are below freezing. Per PBanders, the 311906161C pictured above doesn't allow the CSV to work unless temps are below 7-21 degrees F.
I removed that whole comblomination long ago. I'm not driving that car in sub-freezing weather! (IMG:style_emoticons/default/laugh.gif) What's your symptoms you're trying to resolve? |
stevend914 |
Feb 16 2020, 06:19 PM
Starting the car when it's cold, I drive it every day. |
GregAmy |
Feb 16 2020, 08:30 PM
Starting the car when it's cold, I drive it every day. If it happens when your ambient temps are above freezing, then it's definitely not the CSV and/or temp sensor for the CSV. If it happens *only* when the ambient temps are well below freezing, then possibly. |
stevend914 |
Feb 16 2020, 09:32 PM
Starting the car when it's cold, I drive it every day. If it happens when your ambient temps are above freezing, then it's definitely not the CSV and/or temp sensor for the CSV. If it happens *only* when the ambient temps are well below freezing, then possibly. Since the existing part doesn't work, it just might be the problem. And believe it or not, it gets below freezing here. |
Lo-Fi Version | Time is now: 19th April 2024 - 06:18 PM |
