> What's This Tool ?, Usually Only Used A Couple OF Times
914Sixer
post Feb 14 2020, 02:27 PM
I thought I would see if the group had their thinking caps on. You only need this a couple of times. But the tool is very handy removing the part.
bbrock
post Feb 14 2020, 02:29 PM
Headlight switch removal?
914Sixer
post Feb 14 2020, 02:36 PM
You are close to correct. Escutcheon tool for removing all the dashboard nuts.
rhodyguy
I've had this for years. No idea what it is or what it's for. (IMG:style_emoticons/default/confused24.gif)
914Sixer
post Feb 14 2020, 02:43 PM
It's for removing pins out of later VW and Audi pin plugs . Might be handy to push female ends out of relay board harness plugs.
bbrock
post Feb 14 2020, 03:05 PM
QUOTE(914Sixer @ Feb 14 2020, 01:36 PM) *
Your close to correct. Escutcheon tool for removing all the dashboard nuts.
Ha! I'm claiming it. I just said headlight switch because that's the only one with a shaft that prevents a good ol' nickel or penny being used for removal. (IMG:style_emoticons/default/biggrin.gif)
post Feb 15 2020, 10:21 AM
I made one by cutting a slice from a washer but not nearly as nice as this one. Now is the time for someone to make those available in a non-scratch plastic material. One of these whiz kids could print some, I'm sure. (IMG:style_emoticons/default/beerchug.gif)
- Lo-Fi Version Time is now: 16th April 2024 - 12:06 PM
