2.0 Exhaust bolt |
2.0 Exhaust bolt |
brian minson |
Feb 21 2020, 09:39 AM
Newbie Group: Members Posts: 27 Joined: 10-May 17 From: Gilbert, Arizona Member No.: 21,089 Region Association: Southern California |
I have noticed a exhaust leak on my dual 44 2.0 motor, when I went to re-torque the bolts and found one of the studs on cylinder #2 would just spin and spin and spin...
Any suggestions on fixing this? Brian (IMG:style_emoticons/default/smile.gif) |
Mark Henry |
Feb 21 2020, 09:43 AM
Timesert.
rjames |
Feb 21 2020, 12:03 PM
I'm made of metal Group: Members Posts: 3,932 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest |
If you’re careful you can fix it without dropping the engine.
Don’t over torque the others or you’ll be fixing them too. |
ctc911ctc |
Feb 21 2020, 01:27 PM
Senior Member Group: Members Posts: 892 Joined: 9-June 18 From: boston Member No.: 22,206 Region Association: North East States |
Suggested Torque?
Asking for a friend........... (IMG:style_emoticons/default/smile.gif) (IMG:style_emoticons/default/headbang.gif) If you’re careful you can fix it without dropping the engine. Don’t over torque the others or you’ll be fixing them too. |
GregAmy |
Feb 21 2020, 02:19 PM
Advanced Member Group: Members Posts: 2,298 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States |
If it didn't fall out it might already be a step-stud...
brian minson |
Feb 21 2020, 04:07 PM
I used 16 ft lbs for my exhaust manifold to head bolts.
Brian (IMG:style_emoticons/default/smile.gif) Suggested Torque? Asking for a friend........... (IMG:style_emoticons/default/smile.gif) (IMG:style_emoticons/default/headbang.gif) If you’re careful you can fix it without dropping the engine. Don’t over torque the others or you’ll be fixing them too. |
dr914@autoatlanta.com |
Feb 21 2020, 04:19 PM
914 Guru Group: Members Posts: 7,856 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
get an 8/9 stud and screw it in
I have noticed a exhaust leak on my dual 44 2.0 motor, when I went to re-torque the bolts and found one of the studs on cylinder #2 would just spin and spin and spin... Any suggestions on fixing this? Brian (IMG:style_emoticons/default/smile.gif) |
HansJan |
Feb 21 2020, 07:28 PM
Member Group: Members Posts: 395 Joined: 5-April 16 From: Sugar Land TX Member No.: 19,860 Region Association: Southwest Region |
I have noticed a exhaust leak on my dual 44 2.0 motor, when I went to re-torque the bolts and found one of the studs on cylinder #2 would just spin and spin and spin... Any suggestions on fixing this? Brian (IMG:style_emoticons/default/smile.gif) This totally sucks (happened to me last week). I fixed it with Helicoils, even though Treated inserts might be better. Easy fix with car on jackstands (wear safety goggles). Make sure to anneal the new copper gaskets. It will make them much softer and easier to seal with less torque. |
brian minson |
Feb 21 2020, 07:59 PM
Where can I pick one of these 8/9 studs up at?
Brian (IMG:style_emoticons/default/smile.gif) get an 8/9 stud and screw it in I have noticed a exhaust leak on my dual 44 2.0 motor, when I went to re-torque the bolts and found one of the studs on cylinder #2 would just spin and spin and spin... Any suggestions on fixing this? Brian (IMG:style_emoticons/default/smile.gif) |
Lo-Fi Version | Time is now: 15th May 2024 - 12:55 AM |
