FS: 1976 914-6 3.0L Conversion |
patssle |
Feb 22 2020, 08:53 PM
Senior Member Group: Members Posts: 981 Joined: 28-August 09 From: Houston, TX Member No.: 10,741 Region Association: None |
This is a 1976 Porsche 914 that has a 1981 Porsche 3.0L SC engine. Almost all work done to the car has been done by myself (except wrap, bodywork, and specialty rebuilt parts). I have owned the car since 2009. In 2010 I purchased a project 911 to swap the engine to my 914. After preparing the engine and collecting parts the swap was done in the summer of 2014. I have driven this car every fall and spring when there is nice weather. Mileage of engine and car is unknown. Annual driven estimates are 2-4 thousand miles. Engine pulls hard and is a true blast to drive in this tiny car. Previous owners gutted the car for autocross – this is a lightweight 914. Interior is bed liner – no carpet. No accidents under my ownership. The car has never been towed home. I also own a 2000 Boxster S that I work on myself as well.
$17,000 SOLD Issues: Slight rust issues were fixed by my body guy before being wrapped (paint underneath is faded red). Previous rust issues were already fixed before my purchase (battery hellhole). Racing seats need to be recovered or replaced – I have passenger seat but is not in car. The oil tank oil filter mount was not drilled center so I am using a remote oil mount. This allows for extra oil temp sensors that are featured in the center console and for the remote fan. Engine leaks like any classic Porsche engine as does the oil tank through a fitting or mount I apparently didn’t seal well enough when installed. Speedometer is not accurate – bounces around despite new cable. Specs: 1976 914 with a 1981 3.0L SC engine Weber 40IDA3C Carburetors MSDS 1-5/8 headers DANSK Muffler Sport Polished Stainless Steel (84 mm Dual Tail Pipes) 901 Side Shift Transmission (Rebuilt by Mike Callas / Rennsport Sealy) Patrick Motor Sports Engine Mount Vellios Oil Tank w/ Filler Neck and Dip Stick Kennedy Engineering Flywheel & Stage II Clutch w/ TOB MSD 6AL Ignition Distributor rebuilt and recurved by Barry Hershon (23 crank degrees) Alternator rebuilt by Houston Alternator 911 Starter Mocal 25 Row, 235 Matrix Oil Cooler w/ Remote Thermostat Engine oil cooler modified by Richard Johnson Valvoline VR1 Racing Oil 20w50 Aeroquip Stainless Steel Braided Hose -16 AN Tank to Engine, -12 AN Everywhere Else Gates LP (Low Permeation) Carb Fuel Line 5/16" CB Performance Fuel Pump 3M 1080 Scotchprint Gloss Hot Rod Red Wrap installed by Undergroundgrfx Turbo Tie-Rods Bilsteins P36-0112-H0 Inserts Mahle 5.5x15 Wheels BFG G-Force Sport Comp 2 Tires Front Sway Bar Installed (Rear Available) |
burton73 |
Feb 24 2020, 05:42 PM
burton73 Group: Members Posts: 3,520 Joined: 2-January 07 From: Los Angeles Member No.: 7,414 Region Association: Southern California |
If this car was a 75 or older it would of been gone in a flash
Bob B |
Lo-Fi Version | Time is now: 13th May 2024 - 07:19 PM |
