Fuel tank line access question |
stevegm |
Feb 23 2020, 06:04 PM
Advanced Member Group: Members Posts: 2,111 Joined: 14-July 14 From: North Carolina Member No.: 17,633 Region Association: South East States |
EDIT:
I think I’ve found the problem. See the last post. ——— I’m getting my engine broken in with a single carb. The fuel pump is located in the engine compartment. When I hook the carb up to the fuel line in the car, it doesn’t get fuel. The pump never quiets down, and no fuel. When I put a fuel line from the fuel pump directly to a gas can next to the car, it takes fuel and runs fine. The pump quiets down once it gets fuel. Everything works fine. When I blow air back through the fuel line from the engine compartment, with an air hose, you can hear it coming out in the gas tank. So I don’t think the lines are clogged. Any ideas why I’m not getting fuel out of the main line with the pump? The line is a hard line. It looks like someone has replaced the plastic lines. The car had carbs when I bought it a few years ago. |
iankarr |
Feb 27 2020, 09:40 PM
The wrencher formerly known as Cuddy_K Group: Members Posts: 2,473 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region |
Yes, the fuel sock is behind that fitting. I think the easiest way to prevent kinking is to coil the line before you hook it up. IIRC the ideal length is 21 or 22 inches. Details and how-to towards the end of the fuel line video in my signature below...
Lo-Fi Version | Time is now: 13th May 2024 - 03:21 PM |
