Finding TDC |
Finding TDC |
Olympic 914 |
Feb 25 2020, 05:58 PM
Group: Members Posts: 1,672 Joined: 7-July 11 From: Pittsburgh PA Member No.: 13,287 Region Association: North East States |
Setting timing today, and have used the angle iron bar on the rear wheel to hold that side while I rotated the other wheel. But occasionally if you have to back up a few degrees the bar would lift off the ground. This time I zip-tied a dumbbell to the bar and it held it in place easily.
And rather than bending over the fender with a mirror, harder when up on the lift. I used this wifi Endoscope with a magnetic tool mount. It was REALLY easy to watch on the phone and rotate the engine until the 0 was lined up with the notch. This was the view from the endoscope. It has a built in adjustable light. I may have to try this again next time I set the ignition timing. then I would just have to shine the timing light into the hole and watch on the phone. (IMG:style_emoticons/default/idea.gif) It comes in handy in other ways like feeding down the tunnel to make sure the clutch/throttle cables are not crossed. |
Tbrown4x4 |
Feb 25 2020, 06:53 PM
Senior Member Group: Members Posts: 704 Joined: 13-May 14 From: Port Orchard, WA Member No.: 17,338 Region Association: None |
Great idea!
Lo-Fi Version | Time is now: 22nd May 2024 - 04:41 PM |
