914-4 vs 914-6...heat exchangers, Trying to understand Dansk's price disparity |
horizontally-opposed |
Feb 25 2020, 11:32 PM
Advanced Member Group: Members Posts: 3,432 Joined: 12-May 04 From: San Francisco Member No.: 2,058 Region Association: None |
Another thread got me to thinking about this, and I suppose my honest questions could be construed as an attack on a vendor (not intended), so it's probably better to move the conversation to its own thread.
These 914-4 heat exchangers in mild steel are $268 each: https://www.stoddard.com/022256091f.html These 914-6 heat exchangers in mild steel are $3675 a pair: https://www.stoddard.com/91421100500-sic.html It looks like a mild steel HEs for the 914-4 may or may not be available for $300~ per side while stainless-steel HEs for the 914-4 can be had for $1800~ a pair. Or less. What I am still trying to understand is Dansk's pricing for 914-6 HEs in mild steel. I get that they have an extra exhaust tube each, different head flanges, and more intricate heater boxes, but… (IMG:style_emoticons/default/blink.gif) Anyone and any company is welcome to weigh in with perspective so long as it's respectful. I converted my 914 to a 2.2 six a few years ago, and went with a set of used headers that were handy because I was already over budget and had a tough time justifying the price of -6 heat exchangers for a car I don't use all that often and can choose not to use in cold weather (I doubt I am alone in this). Of the current options, I am most impressed with mb911's stainless setup (expensive but seems like good value) and Dansk's mild steel setup (very expensive and does not seem like good value—unless, that is, factory appearance is critical). Here to learn… |
Feb 26 2020, 07:57 AM
I will say the Dansk units look good as well as very correct.
I appreciate the perspectives of those who make parts for these cars, and those who watch this stuff closely. There has to be margin in these parts, I agree on the tooling costs—though buying John out of SSI may not have been cheap (nor should it have been). Then again, yes, all R&D and all tooling done—which is where I am sure the value of SSI was, alongside sales, customer base, etc. I'm not sure which way I'll go. The car is fine for now, and there are things I'd rather spend $2700-3500 on given the way I use it (sunny days, usually)—though that might change if I find more time to use the car and/or travel in it. The questions for me as a consumer are numerous: Do I need heater boxes designed to cut it in European winters? Would something more minimal do the trick? Maybe one of Ben's headers on one side (passenger?) and a heater box on the other? (If anything, the SSIs I had with the four-cylinder were capable of putting out too much heat—I'm looking to clear the windshield, cut the chill, and keep my feet warm.) Is stainless steel overkill at this point in the car's life vs mild steel with a coating? Could a small clamshell or clamshells be created as an option for Marty's headers? Whatever the case, I am grateful that these parts exist at all. |
mepstein |
Feb 26 2020, 11:33 AM
914-6 GT in waiting Group: Members Posts: 19,272 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
I will say the Dansk units look good as well as very correct. I appreciate the perspectives of those who make parts for these cars, and those who watch this stuff closely. There has to be margin in these parts, I agree on the tooling costs—though buying John out of SSI may not have been cheap (nor should it have been). Then again, yes, all R&D and all tooling done—which is where I am sure the value of SSI was, alongside sales, customer base, etc. I'm not sure which way I'll go. The car is fine for now, and there are things I'd rather spend $2700-3500 on given the way I use it (sunny days, usually)—though that might change if I find more time to use the car and/or travel in it. The questions for me as a consumer are numerous: Do I need heater boxes designed to cut it in European winters? Would something more minimal do the trick? Maybe one of Ben's headers on one side (passenger?) and a heater box on the other? (If anything, the SSIs I had with the four-cylinder were capable of putting out too much heat—I'm looking to clear the windshield, cut the chill, and keep my feet warm.) Is stainless steel overkill at this point in the car's life vs mild steel with a coating? Could a small clamshell or clamshells be created as an option for Marty's headers? Whatever the case, I am grateful that these parts exist at all. How much longer will you be driving your car? If it 10-20+ years, the yearly price difference between cheapest and most expensive isn't that much. There's a good reason why Ben's older M&K mufflers still bring 3/4 the price of new. Quality parts are worth the investment. |
Feb 26 2020, 11:03 PM
How much longer will you be driving your car? If it 10-20+ years, the yearly price difference between cheapest and most expensive isn't that much. There's a good reason why Ben's older M&K mufflers still bring 3/4 the price of new. Quality parts are worth the investment. Yeah, I'm all for quality parts, which are often cheaper in the long run, and very good point too about the yearly cost. I've "justified" plenty of other purchases that way, and rarely regretted doing so. I guess I am just trying to "right size" heat exchangers given how and how much I use my 914 these days. As above: Do I need heater boxes designed for daily use in European winters? Would something more minimal do the trick? Maybe one of Ben's headers on one side (passenger?) with a heat exchanger on the other? (If anything, my 914-4 SSIs were capable of putting out too much heat—I'm looking to clear the windshield, cut the chill, and keep my feet warm.) Is stainless overkill at this point in the car's life vs lesser steel with a coating? |
Superhawk996 |
Feb 27 2020, 05:52 AM
914 Guru Group: Members Posts: 5,824 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
Is stainless overkill at this point in the car's life vs lesser steel with a coating? Personal choice, but, IMHO, stainless is always the right choice for exhaust components. We've all pretty much forgotten how quickly mild steel rusts out in an exhaust since stainless has become the norm on OEM exhaust systems due to 10 year mandate w.r.t emissions integrity of the system. Exhaust sytems constantly have condensation in them combined with an corrosive mix of emission particles. Rots mild steel from the inside out. Back in the day of mild steel, in the mid-west rust belt, it wasn't uncommon to have to replace mufflers and pipes every 4 years or less due to corrosion. Now stainless exhaust systems largely last the life of vehicles. |
mb911 |
Feb 27 2020, 06:52 AM
914 Guru Group: Members Posts: 6,851 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
Is stainless overkill at this point in the car's life vs lesser steel with a coating? Personal choice, but, IMHO, stainless is always the right choice for exhaust components. We've all pretty much forgotten how quickly mild steel rusts out in an exhaust since stainless has become the norm on OEM exhaust systems due to 10 year mandate w.r.t emissions integrity of the system. Exhaust sytems constantly have condensation in them combined with an corrosive mix of emission particles. Rots mild steel from the inside out. Back in the day of mild steel, in the mid-west rust belt, it wasn't uncommon to have to replace mufflers and pipes every 4 years or less due to corrosion. Now stainless exhaust systems largely last the life of vehicles. (IMG:style_emoticons/default/agree.gif) Most have forgotten that.. Also keep in mind that Dansk is a big business.. They have to make sure everything pencils out .. The amount of 914-6 conversion is likely growing but if you real market is the 3000 original cars and the 6 or 7000 conversions thats incredibly small market.. Now how many folks building a conversion are using small engines besides me and @superhawk996 that would be fine with the primary sizing of 1.5? An even smaller percentage.. Most conversions I see are 3.0 and above.. Again I say economy of scale.. |
Lo-Fi Version | Time is now: 16th May 2024 - 08:45 PM |
