I've checked everything, what's left?, My car is downright REFUSING to run |
JDW914 |
Feb 26 2020, 05:48 PM
Newbie Group: Members Posts: 25 Joined: 27-April 11 From: Toledo, Ohio Member No.: 12,990 Region Association: Upper MidWest |
Okay, so a bit of background.
Late last year, my car ('74 2.0 with Mark De Bernardi's 2056 hardware kit) suffered a betrayal from one of the old Bosch injectors, resulting in a fire which, while happily small and caught quickly, ruined the engine wiring looms, MPS, and battery. I figured repairs would be pretty straightforward - and they were. Got parts frome eBay, and new looms from Jeff Bowlsby, took the car to the shop of the painter who did the original restoration bodywork on it, and dropped, cleaned, and rewired the engine while he fixed the decklid and rollbar up. Threw the engine back in, got it running, tuned it to perfection, and went to reassemble the car. Now this is the point where everything started going very wrong. We put the decklid in place and went to install the trunklid, and the trunk hinges both sheared at the bolt. I replaced the bolts, and we noticed the sheet metal flex mounts for the hinges were both nearly undone at the welds as well, so the painter offered to weld them up, which I agreed to. We disconnected the battery just in case, welded them up, and assembled the car. I got in to drive it away, and the car would not start. Engine turns over, kicks into life, then dies. And this is all I've gotten it to do since, and I am out of ideas. EVERYTHING checks out and is working, to the point where I'm not sure how it's physically possible that this thing isn't running. So far, I have verified: - There is good fuel pressure (32-33psi at prime, 33-35psi during cranking and running) - All 4 injectors (matching, new SMP FJ6 units) are firing - There is spark, and it is timed correctly - The point dwell is optimal (about 47 degrees) - There is strong compression (around 140-155# in all cylinders) - The valves are all actuating, and have correct lash - All electrical and pneumatic connections are secure And I have tried: - Draining the tank and using fresh fuel (what was in it was several months old) - Swapping coils from the stock-alike to an MFD Blaster 2 with appropriate ballast in case the coil was failing to charge up at running speeds - Swapping the ECU out between a NOS replacement and the original which seems to be free of damage - Setting fuel pressure all the way up and all the way down as far as the Bosch regulator allows - Clamping off the cold-start injector - Starting the engine while hooked up to a battery charger - Unplugging the TPS Not a thing so far has produced the slightest change of behavior. The closest I've gotten to having it run is, with WOT, holding the starter keeps the engine "running" at about 800rpm, with constant combustion, but no pickup of rpms or power, which is still pushing me towards either spark or fuel mixture. What has me completely aghast, though, is that this thing was running perfectly and not a thing has changed. I'm beginning to think it's just angry at me. What the heck am I missing? |
Root_Werks |
Feb 26 2020, 06:05 PM
Village Idiot Group: Members Posts: 8,315 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest |
It sounds like you're not getting past the cold start cycle.
914_teener |
Feb 26 2020, 06:38 PM
914 Guru Group: Members Posts: 5,197 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
So did you get a new MPS and calibrate after the old one burned and was destroyed or did we miss something.
JeffBowlsby |
Feb 26 2020, 07:04 PM
914 Wiring Harnesses Group: Members Posts: 8,491 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
I usually dont jopi nthese discussoin, but here goes:
1. What MPS part number do you have and does it hold steady vacuum? 2. Known good original MPS or recent rebuild? 3. Fuel pressure is too high, should be about 28-30psi if I recall correctly. Check the factory specs. 4. Trigger points verified to function? 5. Fuel injector grounds connected to ground? |
JDW914 |
Feb 26 2020, 07:38 PM
Yes - I should have specified better - I did replace the MPS. The old one was pretty much destroyed.
The new one is a -043 P/N that has been re-manufactured by Rich Bontempi. It holds vacuum and the impedance is in the right area. The fuel pressure is boosted to match the more aggressive cam and slightly increased displacement (although I based my calculations on a 32psi stock spec and the Bosch injectors). I'll redo the calculations for the new injectors and readjust it more precisely when the thing runs again. Trigger points are working, as the injectors are pulsing (I've squirted fuel into a jar out of all 4 with the engine cranking). Is there a good way to tell if they're consistent? It's crossed my mind that they might be intermittent or sticky. The injectors ground to the stud at the back at the back of the block, right? I'll double check continuity when I get a chance to be sure of them, but that ground is secure. |
914_teener |
Feb 26 2020, 07:49 PM
I usually dont jopi nthese discussoin, but here goes: 1. What MPS part number do you have and does it hold steady vacuum? 2. Known good original MPS or recent rebuild? 3. Fuel pressure is too high, should be about 28-30psi if I recall correctly. Check the factory specs. 4. Trigger points verified to function? 5. Fuel injector grounds connected to ground? I.ll just go there: Story isn.t plausible given the name dropping going on....big qualifier......... IMHO. |
rjames |
Feb 26 2020, 08:26 PM
I'm made of metal Group: Members Posts: 3,924 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest |
MPS needs to be calibrated to your engine.
JDW914 |
Feb 26 2020, 08:57 PM
I usually dont jopi nthese discussoin, but here goes: 1. What MPS part number do you have and does it hold steady vacuum? 2. Known good original MPS or recent rebuild? 3. Fuel pressure is too high, should be about 28-30psi if I recall correctly. Check the factory specs. 4. Trigger points verified to function? 5. Fuel injector grounds connected to ground? I.ll just go there: Story isn.t plausible given the name dropping going on....big qualifier......... IMHO. Don't know what to say to that. I'm name dropping because A. those are the people I got the parts from and B. I'm fairly certain that the new components are good, and wanted to communicate that these aren't random junk parts or shoddy replicas. Honestly, the situation the car is in seems basically impossible to me. It was JUST working. I'm basically hoping somebody will come along and point out something stupid simple that I've missed. MPS needs to be calibrated to your engine. This is new to me. I know that there are several available adjustments, but I was under the impression that messing with any of it "should be a LAST RESORT process" and "you'll usually be better off if you get a rebuilt unit and send in yours as a core." How would I go about it? |
iankarr |
Feb 26 2020, 08:59 PM
The wrencher formerly known as Cuddy_K Group: Members Posts: 2,472 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region |
Cylinder head temp sensor?
second wind |
Feb 26 2020, 10:26 PM
Senior Member Group: Members Posts: 851 Joined: 30-December 10 From: Los Angeles, California Member No.: 12,543 Region Association: Southern California |
My car was down for three months and I "thought" I had spark. Under compression spark plugs do funny things. Replaced the coil and car has run fantastic ever since. Just an idea.
All the best, gg |
porschetub |
Feb 27 2020, 12:06 AM
why up the fuel pressure for a big cam …..never heard of that but my skills are with later systems but still don't see it working.
falcor75 |
Feb 27 2020, 03:01 AM
Senior Member Group: Members Posts: 1,579 Joined: 22-November 12 From: Sweden Member No.: 15,176 Region Association: Scandinavia |
"Not a thing so far has produced the slightest change of behavior. The closest I've gotten to having it run is, with WOT, holding the starter keeps the engine "running" at about 800rpm, with constant combustion, but no pickup of rpms or power, which is still pushing me towards either spark or fuel mixture."
I guess this is with the key in the "engine start" position, does it die when you release the key? I would try taking the ignition lock ou of the equation, bridge the fuel pump to run on the relay board and then just use a remote starter switch directly on the starter motor. Gearbox earth strap in place? |
BeatNavy |
Feb 27 2020, 05:42 AM
Cylinder head temp sensor? Given everything else you've described, this would be one of my prime suspects -- the CHT. I think you're on the right track with fuel mixture, and if the CHT is bad or the circuit broken it may initially attempt to start but will quickly flood and not do anything after that until the fuel evaporates. Then you can try again, and the cycle repeats. Does this sort of describe the behavior? If you pull the plugs after attempting to start, are they wet? Easy enough to check. Situations like this you definitely need to go back to rock solid fundamentals of spark, fuel, compression, timing and verify them 100%. |
JDW914 |
Feb 27 2020, 09:49 AM
The CHT is a good call. I will check it out and make sure it's got the right resistance.
I'll also check the plugs for signs of rich/lean running. I don't think it's ignition switch related as the engine does run with the key released, just only for a few seconds. It actually starts and catches quite quickly. |
914_teener |
Feb 27 2020, 10:11 AM
Cylinder head temp sensor? Given everything else you've described, this would be one of my prime suspects -- the CHT. I think you're on the right track with fuel mixture, and if the CHT is bad or the circuit broken it may initially attempt to start but will quickly flood and not do anything after that until the fuel evaporates. Then you can try again, and the cycle repeats. Does this sort of describe the behavior? If you pull the plugs after attempting to start, are they wet? Easy enough to check. Situations like this you definitely need to go back to rock solid fundamentals of spark, fuel, compression, timing and verify them 100%. Without a ground to the CHT.....the engine will not run....period. So.......the OP states ......everything was fine until he had an engine fire burning up harnesses. That.s nothing trivial. He should begin by ringing out any circuit connected to rhose harnesses to prove them out to eliminate each possiblity. Again not a trivial task and without a systematiic approach instead of wishful or magical thinking a solution will be slow in coming. |
GregAmy |
Feb 27 2020, 10:14 AM
Advanced Member Group: Members Posts: 2,290 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States |
Data point: my intermittent start, start then dies, random dies.
http://www.914world.com/bbs2/index.php?sho...=291477&hl= Spoiler alert: bad MPS diaphragm. It held vacuum. |
rjames |
Feb 27 2020, 01:36 PM
QUOTE This is new to me. I know that there are several available adjustments, but I was under the impression that messing with any of it "should be a LAST RESORT process" and "you'll usually be better off if you get a rebuilt unit and send in yours as a core." If the diaphragm is toast the car may not run. If you replaced your original mps it is likely that it will need to be tuned to your engine, even if it was recalibrated to factory specs. To adjust it you’ll need to be able to get to the adjustment screws (do a search- lots of threads on adjusting the MPS) and have access to a wideband AFR meter. |
914sgofast2 |
Feb 27 2020, 02:26 PM
Senior Member Group: Members Posts: 614 Joined: 10-May 13 From: El Dorado Hills, CA Member No.: 15,855 Region Association: None |
Guys, You can’t set the MPS if the motor won’t run!
I suggest checking to make certain the engine/trans are securely grounded. Check for presence and cleanliness of the ground strap between the rear of the trans and body. Because the car was repainted due to the engine fire, also check (1) battery negative cable connection to body is sparkling clean; (2) all the wires going to the grounding point behind terminal/relay board in left (driver) side of engine compartment are clean and paint free. |
Resident German Group: Admin Posts: 41,625 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Olympic 914 |
Feb 27 2020, 03:07 PM
Group: Members Posts: 1,662 Joined: 7-July 11 From: Pittsburgh PA Member No.: 13,287 Region Association: North East States |
The CHT should read somewhere around 2500 Ohm resistance cold and then go down to below 100 when hot.
You could trick the ECU by substituting a 2500 Ohm resistor between the lead where the cht plugs in and ground. That would mimic a cold situation to the ECU. it should work to at least start the engine. But if left in place it would be too rich to drive around after warmed up. |
Lo-Fi Version | Time is now: 8th May 2024 - 01:34 PM |
