Should I move my fuel pump? |
dr914@autoatlanta.com |
Mar 25 2020, 02:25 PM
914 Guru Group: Members Posts: 7,858 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
no only if it is causing vapor lock. Make sure all of the plumbing is tightly installed and the fuel pump is correctly mounted and that the bellows flaps are installed and the engine is running as cooly as possible and you should be ok
I've been working hard on my newly-acquired 73 2.0. Thanks to everyone on this site for all the inspiration and motivation! Currently have engine out, engine compartment stripped, interior stripped, gas tank out. Since the car has been sitting for 30+ years, i decided I would replace all the fuel lines. I plan to buy a complete stainless fuel line kit from Tangerine. In the state I'm at currently, it would be an ideal time to re-locate the fuel pump. I plan to keep the D-jet injection. Should I move the fuel pump to under the tank? Are there any down sides to this? What pump should I get? Thanks in advance, Aaron |
Lo-Fi Version | Time is now: 17th May 2024 - 07:52 AM |
