1975 (7pin) Ljet air box, mass air flow, injectors, relays, and full engine harness, very good condition |
brant |
Mar 2 2020, 10:34 AM
So these were all for a 1975 motor that unfortunately died
They system has been stored in doors for nearly 20 years the rubber, and plastic is all soft and supple none of the engine boots are cracked none of the wire sheathing is cracked I did not test all of the harness. I started testing for continuity and then gave up as I don't have time for it. More cleaning would help I did not use any solvents I wiped off some of the shelf dust, but nothing is as clean as it could be. the injectors were reported to be rebuilt, but I have no way to test the system was from a running motor... (Previous owner allowed car to sit outside briefly and get water into the block during install with injection parts not installed) both of the pictured relays are included but untested The air flow box is not molested. all factory seals still in place and flapper door moves easily let me know what questions you have I don't know how to test they system better without a car or power source. $400 plus shipping brant Attached thumbnail(s) |
Lo-Fi Version | Time is now: 16th May 2024 - 10:05 PM |
