How to bring new life to original HE, No rust or issues with them. Just need to refresh |
JRust |
Mar 7 2020, 01:58 PM
914 Guru Group: Members Posts: 6,307 Joined: 10-January 03 From: Corvallis Oregon Member No.: 129 Region Association: Pacific Northwest |
Okay on my 73 2.0 resto I am wondering what to do for my HE. While some Stainless would be nice. My stock ones are in great shape. So I just want to make them look nice again. What do you guys recommend? What have you done with good results? Thought about Ceramic coating them but not even sure that would work.
Attached thumbnail(s) |
Mar 7 2020, 02:07 PM
914-6 GT in waiting Group: Members Posts: 19,269 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
I would take them to someone who will blast them and then either paint them with VHT paint or get them ceramic painted.
914werke |
Mar 7 2020, 02:18 PM
"I got blisters on me fingers" Group: Members Posts: 10,058 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
1st step is kill the rust. short of ripping them apart the only way is to immerse them.
Find yourself a container that one will fit in completely & be tall enough to cover the down pipes. Buy a few gals of Apple cider vinegar min 5% acidity fill the sucker up & let soak for a day or two. Wash & neutralize with a bake soda THEN blast the outsides & paint with a HI zinc content paint like a cold galvanizing compound. Cheap & effective |
GeorgeRud |
Mar 7 2020, 05:16 PM
I sent mine out for ceramic coating and they came back looking great. I used Jet-Hot for the coating.
orthobiz |
Mar 7 2020, 05:23 PM
Senior Member Group: Members Posts: 1,754 Joined: 8-January 07 From: Cadillac, Michigan Member No.: 7,438 Region Association: Upper MidWest |
914werke |
Mar 7 2020, 05:43 PM
(IMG:style_emoticons/default/blink.gif) (IMG:style_emoticons/default/confused24.gif) if all your interested is how nice they look on the outside & are ok with breathing heated ferric oxide... (IMG:style_emoticons/default/icon8.gif)
You could just blast & ceramic coat (IMG:style_emoticons/default/screwy.gif) |
IronHillRestorations |
Mar 7 2020, 05:53 PM
I. I. R. C. Group: Members Posts: 6,717 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
I'd go for Jet Hot coating too. I had a set of 6 heat exchangers done, and they've held up great
worn |
Mar 7 2020, 06:30 PM
can't remember Group: Members Posts: 3,153 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest |
(IMG:style_emoticons/default/blink.gif) (IMG:style_emoticons/default/confused24.gif) if all your interested is how nice they look on the outside & are ok with breathing heated ferric oxide... (IMG:style_emoticons/default/icon8.gif) You could just blast & ceramic coat (IMG:style_emoticons/default/screwy.gif) Just saying that there is quite a lot of ferric oxide in nature. And in cereals boosted with iron. I would worry more about CO. Sounds and looks like these are in pretty good shape though. |
stevesc_us |
Mar 7 2020, 11:55 PM
Member Group: Members Posts: 69 Joined: 12-February 06 From: Redwood City, CA Member No.: 5,569 |
rgalla9146 |
Mar 8 2020, 06:19 AM
Advanced Member Group: Members Posts: 4,552 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
Mar 8 2020, 11:50 AM
I'd go for Jet Hot coating too. I had a set of 6 heat exchangers done, and they've held up great Can Jet Hot be done in dull grey like the original color ? They have a few color options, including a nice gray Jet Hot Coatings |
914werke |
Mar 14 2020, 03:50 PM
To my earlier point here is some correspondence I got from Jet hot related to plating heater boxes:
QUOTE [for the heat exchangers] We do a thermal de-grease process and a media blast. We can only get to the outside only, and it would have to be in satin silver or a color. The reason why we can't do polish, is our vibe tank has tons of small ceramic beads that get stuck and tend to rattle after install. ASHLEY BARCZY Jet-Hot, High Performance Coatings In other words they cook any part they receive to burn off grease & contaminants then they blast them before coating. ...Just like any plater/powder coater worth their salt. The problem remains for OE mild steel HE's which are likely rusty inside the boxes, that de-grease process wont affect or remove that rust. Since the air path for the heated air includes those rusty pipes ..<insert coughing emoji> Pretty on the outside rusty on the inside. (IMG:style_emoticons/default/shades.gif) |
JRust |
Mar 14 2020, 05:44 PM
To my earlier point here is some correspondence I got from Jet hot related to plating heater boxes: QUOTE [for the heat exchangers] We do a thermal de-grease process and a media blast. We can only get to the outside only, and it would have to be in satin silver or a color. The reason why we can't do polish, is our vibe tank has tons of small ceramic beads that get stuck and tend to rattle after install. ASHLEY BARCZY Jet-Hot, High Performance Coatings In other words they cook any part they receive to burn off grease & contaminants then they blast them before coating. ...Just like any plater/powder coater worth their salt. The problem remains for OE mild steel HE's which are likely rusty inside the boxes, that de-grease process wont affect or remove that rust. Since the air path for the heated air includes those rusty pipes ..<insert coughing emoji> Pretty on the outside rusty on the inside. (IMG:style_emoticons/default/shades.gif) Hey Rich, So if I used the process you recommended to get rid of the rust. Would jet-hot coating them after be okay? |
914werke |
Mar 14 2020, 06:08 PM
Absolutely
Mark Henry |
Mar 14 2020, 07:40 PM
1st step is kill the rust. short of ripping them apart the only way is to immerse them. Find yourself a container that one will fit in completely & be tall enough to cover the down pipes. Buy a few gals of Apple cider vinegar min 5% acidity fill the sucker up & let soak for a day or two. Wash & neutralize with a bake soda THEN blast the outsides & paint with a HI zinc content paint like a cold galvanizing compound. Cheap & effective For this to be real effective shouldn't you hot tank the exchanger first to get rid of the baked on grease? |
Lo-Fi Version | Time is now: 13th May 2024 - 07:50 PM |
