FS Early Turn signal switch, ignition switch, Asking $50 each shiped |
bdstone914 |
Mar 8 2020, 08:14 AM
bdstone914 Group: Members Posts: 4,521 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Will post pics later.
I have an early turn signal switch that appears to have no wear on the contacts. Wire ends were cut at the bottom. Will require splicing your terminal ends. Ignition switch is of unknown brand without key. Wire ends were cut at the bottom. Will require splicing your terminal ends. Not tested but if either part does not work I will give a full refund without return of the part. Bruce |
Lo-Fi Version | Time is now: 15th May 2024 - 01:59 PM |
