GB for Speedometer drive bushing that stops leaks, Comes will all seals needed GB ENDS TOMORROW $52 for ALL |
Mikey914 |
Mar 12 2020, 10:07 AM
The rubber man Group: Members Posts: 12,667 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
What does this part do? Well is adds a second seal around the base of the opening in the transmission housing. Doing so adds a second barrier to help keep that annoying little drip on you garage floor.
We provide The bushing both outer seals and the internal seal You will need to re use your aluminum washer. Or we can sell you one, but these typically are not an issue. Just need 10 takers to get this price. Just to give you an idea the factory part alone is about $90, and it only has the one seal. SO who's in? Attached thumbnail(s) |
Mikey914 |
Mar 23 2020, 05:10 PM
We are just awaiting some material, we will have this week. There are 3 ops on this part so it takes a little longer to get through the system.
We want to get these out as soon as possible to give folks something to do. |
Nogoodwithusernames |
Mar 23 2020, 05:17 PM
Member Group: Members Posts: 236 Joined: 31-May 16 From: Nor-Cal Member No.: 20,051 Region Association: None |
We are just awaiting some material, we will have this week. There are 3 ops on this part so it takes a little longer to get through the system. We want to get these out as soon as possible to give folks something to do. (IMG:style_emoticons/default/beerchug.gif) |
Lo-Fi Version | Time is now: 15th May 2024 - 11:46 PM |
